08-30-2023, 08:04 PM | #1 |
Rep 167
Best Offset for Flush Fitment???
What's up gang.
Im ordering custom wheels and need to know what the offsets needed are for a 20 x 10 front and 20 x 11.5 rear. Going to run 275/35/20 tires in front and 305 or 315/30/20 in rear. Help a brother out 🙏🏻🙏🏻🙏🏻 |
08-31-2023, 01:32 PM | #2 |
Rep 2,352
Here is my setup, similar to what you are looking for
https://www.6post.com/forums/showthread.php?t=1677487
BMWisBest120.00 |
08-31-2023, 02:22 PM | #3 | |
Rep 167
Also is this flush with the fenders? Do you have any pictures that show how they line up? |
08-31-2023, 02:56 PM | #4 | |
Rep 167
I want to camber the fronts top -2.5 and trying to confirm if I would have room if possible! |
09-02-2023, 03:18 PM | #5 | |
Rep 7,584
I would suggest running a comparison of your existing wheel tire set up to your new wheel tire set up at this site: www.willtheyfit.com You will have to measure your existing distance from the fender and suspension to compare what (if any) difference you’ll get from the new setup. (How much poke toward the fender or inset toward the suspension) This can also help if the new specs do not push the wheels out flush with the fender…you’ll now what size spacers you’ll need…or different wheel/tire selection to make to get the flush you’lre looking for.
09-03-2023, 02:36 PM | #6 |
Rep 2,352
Here's another one for you, the offsets are really good - I'm at stock ride height so if you lower it the top will tuck in a little bit
09-05-2023, 09:44 AM | #7 |
Rep 228
BMWisBest
We recommend for ideal tuner fitment the specs as designed on our M6 version our new GT3R wheelset: https://www.richlandforged.com/product/M5M6GT3R/35 20x10" ET+25 20x11.5" ET+16 Recommended tires: 275/35/20, 315/30/20
BMWisBest120.00 |
09-05-2023, 09:56 AM | #8 | |
Rep 167
Will there be room in the front to increase camber to let's say -2.5? |
09-05-2023, 07:37 PM | #9 | |
Rep 228
Even at -2.5, approximately 10mm of headroom should be available, of course dependent on exact sidewall profile/make,model of tire.
09-24-2023, 08:55 AM | #11 |
Rep 185
Drives: 2013 BMW ///M6 F13
09-25-2023, 02:07 PM | #12 | |
Rep 2,352
The Cup 2s absolutely ruined the rocker panels (or side skirts depending on your region) and rear bumper after a few hot days on new loose chip roads. But the PS4Ss aren't as bad and driving a bit slower on loose chip roads has kept the rear bumper looking good after a respray. I now have PPF on the rocker panels
danielgmanm688.50 |
