Thread Tools |
| 03-25-2026, 08:56 AM | #1 |
![]() 267
Rep 232
bought a set of 20" wheels(birthday present for myself). how do I ceramic coat them?
bought a set of almost new 20" wheels(early birthday present for myself).
how do I ceramic coat them before installing them on my car? is it pretty much the same way as ceramic coating the rest of the car? inside of the wheels is always the dirtiest part of the car due to crap from the road and brake dust. are there heavy-duty and/or special ceramic coatings designed for the wheels? thanks in advance! |
| 03-25-2026, 09:02 AM | #2 |
![]() ![]() 219
Rep 399
Clean them with rubbing alcohol and then apply wheel ceramic coating on them. It's just like ceramic coating that you apply on the body paint.
This is what I used https://amzn.to/4uQ1a3R
DavyNM266.50 |
| 03-25-2026, 12:33 PM | #3 |
YNWA
1539
Rep 1,217
I would use a proper "panel wipe" spray (like often used on car paint, pre-coating) rather than simple IPA. They're only like $10-15 for a bottle. But IPA is better than nothing I guess. Soapy water would prob be fine given that it's a new set of wheels.
Get some vinyl gloves and a foam or MF applicator and wipe them down with the coating, then wipe off with with a short nap (pearl is best) weave 80/20 mf towel (probably 2 wipe offs). Some coatings need to be wiped off immediately; some up to 10 minutes sitting. I like Gyeon, but Carpro, Gtechniq, armour detail supply, adams et al are great.
/// 2004 Silvergrey M3 · Coupe · 6MT · Slicktop · zero options
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54 |
| 03-25-2026, 03:11 PM | #5 | |
![]() 266
Rep 153
Drives: 2026 Z4 M40i Handshalter
I just did the wheels on the Z4 yesterday. I bought two bottles. I guess I lay it on a little heavy. Plus I wanted some to do the calipers too. I also not only the barrels, but the inside of the spokes as well. My wheels were just a few weeks old, and had been cleaned recently, so they were not too bad to begin with. Yesterday I still cleaned them with Griots Heavy Duty Wheel Cleaner. Then hosed them down and dried thoroughly. And prior to ceramic coating each one, they were cleaned with CarPro Eraser. The wheels are tedious, but well worth the effort. And changing to ceramic brake pads for daily drivers or weekend cars helps too to keep them clean. |
lllRazorlll218.50 |
| 03-25-2026, 03:15 PM | #6 |
YNWA
1539
Rep 1,217
You might be surprised how little coating is needed on the surface.
| 03-25-2026, 07:03 PM | #7 |
![]() 229
Rep 223
Don't put it on heavy around the wheel weights. The coating will soak into the foam and sit on the edge making a ridge.
You will not know until it's time for new tires. I take my own weights off and this last time I had 2 wheels with a ceramic line that is better left alone after removing the weights. |
| 03-26-2026, 07:00 AM | #8 |
![]() 4469
Rep 2,381
Drives: BMWs, duh
Though it's more of a pain, applying the coating to a wheel that's off the car is easier in the end and allows you to better reach hard to get to parts of it. If you're going to take the time to coat the wheels you might was well put in a bit more effort to do it right, IMO.
| 03-26-2026, 08:48 AM | #9 |
![]() 208
Rep 178
Consider the wheel weights. So be sure not to coat the barrels until after the tires are mounted and balanced. When I coat the barrels, I wipe the coating on and don't buff it off. Use the applicator to level it and leave it. This leaves a lot more product on for longevity, but if you get the tires changed in short order you will need to polish it off.
For the faces, it's the same as doing the car. You clean them thoroughly, wipe with a panel wipe and/or 50/50 iso/water, then dry completely. Using a blower is pretty much essential if you're going to coat them right after washing. Wheels have tons of little crevices where water gets trapped and they will take a while to air dry. Either leave them in the sun, or blow them off completely with a blower to get ALL the water off. That's essential to ensure the coating adheres. If you get a little water on your applicator, it'll contaminate the product and you'll be wiping water around on the wheel and the coating won't adhere. You won't be able to tell water from product. 100% dry is key. And I'd say you need to do them off the car for best results. There's just no way to get the coating into all the little crevices with the wheels on the car, and the job is much more difficult. |
| 03-26-2026, 12:11 PM | #10 |
Rep 24
Piggybacking on the OP's inquiry...
If I purchase a new set of rims (tires not installed yet), considering the wheel weights need to be installed BEFORE the Ceramic Coating, what is the recommended order of operation? 1) Bring rims + tires to local shop to assemble them together, and add wheel weights (dumb question... do the wheels need to be installed on the car to properly install weights?) 2) Bring set back home to apply ceramic to fully assembled wheels (off of car) 3) Bring finished wheels back to local shop to install on the car (I don't own tools or have the space to remove/install the wheels myself) Thank you in advance... |
| 03-26-2026, 04:58 PM | #11 | |
![]() 267
Rep 232
once I coat the wheels and install them to the car, can I still use wheel cleaners in the future? or will wheel cleaner or iron remover chemicals end up wiping out the ceramic coating? thanks! |
| 03-26-2026, 06:41 PM | #12 | |
YNWA
1539
Rep 1,217
I would assume the typical, more caustic, wheel cleaners would break down the coating faster. LIke those wheel brite type cleaners. Not to mention the physical abrading while cleaning. So I use touchless as much as possible. Wheels coated, use the iron removing type spray (griot's wheel HD or meg's ultimate wheel), then hit it with nanoskin recharge (like wetcoat) to help keep the coating alive so to speak. Then blowdry.
| 03-27-2026, 03:49 AM | #13 | |
![]() 208
Rep 178
The weights are added after the tire is mounted to the wheel. Then they are mounted to the car. Wheel coating doesn’t last as long as coating on the car’s paint, and is something you generally need to repeat once per year. So without being able to remove the wheels from the car, you’ll have to re-coat them while mounted next time. You won’t be able to clean the barrels sufficiently to re-coat those, hence why I mentioned skipping that and just doing the faces. Hope that helps. |
| 03-27-2026, 07:21 AM | #14 | |
![]() 4469
Rep 2,381
Drives: BMWs, duh
At any rate, this is the strategy I'm going to use and adjust as needed. |
DavyNM266.50 |
| 03-31-2026, 12:17 PM | #16 | |
![]() 267
Rep 232
What happens if I apply ceramic coating to the satin/matte finish? Thanks! |
| Bookmarks |
