05-10-2024, 09:20 AM | #1 |
Rep 35
Had a little accident
What is the part on the video called, looking to buy a replacement.
https://vimeo.com/944847790?share=copy |
05-10-2024, 03:04 PM | #2 |
Rep 266
marlboroplug3.00 |
05-10-2024, 03:37 PM | #3 | |
Rep 35
05-11-2024, 08:05 AM | #4 |
Rep 7,590
I can't tell from your posts if you're asking about the damage on the exterior of your car...or if the video is referring to you wanting info about the stuff behind the kidney grilles and front bumper.
Since its unclear if you're looking for exterior or the stuff behind the front bumper...here's links to both that may help you help us determine what you're asking: https://www.realoem.com/bmw/enUS/sho...diagId=51_8392 https://www.realoem.com/bmw/enUS/sho...diagId=51_8446
marlboroplug3.00 |
05-11-2024, 08:08 AM | #5 |
Rep 2,926
marlboroplug3.00 |
05-11-2024, 08:09 AM | #6 |
Rep 7,590
BTW...if you like the redesigned 9 slat kidney grilles found on the facelift f06/f12/f13...then now would be the time to do that mod. They are a direct replacement…and can give a subtle change in how the front end looks. Most may not even recognize the change but may give pause as those familiar with the front end try to figure out what’s different.
9 slat grille is on top…10 slat grill is on the bottom:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 05-11-2024 at 08:26 AM.. |
05-11-2024, 08:14 AM | #7 | |
Rep 35
05-11-2024, 08:15 AM | #8 |
Rep 35
05-11-2024, 08:17 AM | #9 |
Rep 35
05-11-2024, 08:33 AM | #10 | |
Rep 7,590
If you are unsure of the part…if you’re doing this on your own instead of the dealer or an authorized insurer/professional…you should look for the BMW 11 digit (or sometimes the last 7 digit) part number which should be found on each piece.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 05-11-2024 at 08:39 AM.. |
marlboroplug3.00 |
05-11-2024, 08:41 AM | #11 | |
Rep 266
Air duct front bottom Maybe get one from a breakers yard with a car with rear end damage or ebay https://www.ebay.com/itm/386217238200 Cheap set grilles here https://www.ebay.com/itm/186365085960 Last edited by PixelVogue; 05-11-2024 at 08:47 AM.. |
marlboroplug3.00 |
