08-20-2023, 04:29 AM | #1 |
Rep 5
bmw 640d F13 m sport coupe rebuilt engine and loads of extras
People in this forum know how knowledgeable I am on BMWs so this 640 was well looked after and any retrofits are done properly Bmw 640d Sports Auto F13 Coupe Massive spec over 90k new with over 20k of factory optional extras including...
The engine was completely rebuilt only 4000 miles ago Run in with Castrol 5w 30 LL04 oil then changed again at 1000 miles. Car has covered 4000 miles since then. New crank. New pistons, rings & conrods. New big end and main bearings. New front & rear main seals. New OEM oil pump. New timing chains, sprockets & guides tensioners. New OEM oil filter housing and cooler. New OEM rocker cover. New Fuel pump & cam sprockets Cylinder head has been completely refurbished pressure & leak tested with new valve stem oil seals, valves lapped and face skimmed. http://www.cylinderheadservices.co.uk Elring head gasket and bolts. Injectors tested. Every single O ring and gasket on this engine has been replaced. Brand new EGR valve and cooler replaced by sytner BMW. New air con condenser & drier. Bottom end was rebuilt by M Kraft BMW Specialist in Norwich. Engine runs spot on without issue. New air-con condenser & drier and re-gas. Gearbox serviced. Compete gearbox service with ZF pan and fluid, full drain and flush including torque convertor, cooler and lines. Gearbox changes silky smooth in all modes. 50 miles ago serviced the car again with Castrol 5w 30 LL04 and a Bosch oil filter and air filter. Full service history in NBT EVO and in service book The car has been remaped with stage 1 plus to 380HP Its a pleasure to drive with no faults at all. Everything works as it should Car was Cat S with a small damage in front right corner but all parts have been replaced with BMW parts and a very expensive paint No damage to wheel or frame, just bumper, headlight, brackets wing and bonnet |
09-01-2023, 10:44 AM | #2 |
Rep 60
Hi Biofotis, lovely car. I saw in a post that you used a chinese can filter for your evo retrofit, would you be able to point me in the direction for purchase, i need one for my car, thankyou.
