      07-04-2023, 12:41 PM   #1
BMWBudgie
BMWBudgie's Avatar
22
Drives: BMW 320i M Sport F30
Hardwired dash cam
Hey all, sorry if not I’m the correct thread…
However, I am looking to hardwire my DASH cam into my new F40 2 Series GC. As then it won’t be plugged into the standard cigarette port…
However, I have no idea what I’m looking at when it comes to fuses and where it needs to be plugged into. 1 wire needs to go into a ACC fuse port, and the other wire is BATT, so when the engine is off it doesn’t take power from ACC and the battery only…if that makes sense
I have attached images with hope someone can help me
      07-04-2023, 01:04 PM   #2
TheMidnightNarwhal
TheMidnightNarwhal's Avatar
3066
Drives: 2024 Golf R DSG Lapiz
You can use a test light/other suitable tool to probe your fuses and check which one are on in the state you want it. BATT is usually a fuse that always has power even with car off (for your parking mode to work) and ACC goes on a fuse that is only on when ignition or accessory is on to tell the camera when to switch from parking to normal mode and other way around.
