      06-10-2023, 08:52 AM   #1
Dasky_spas
Drives: Bmw
Anyone running Mishimoto oil cooler?
Anyone running their performance oil cooler, in particular, in the northeast or someplace where there's a cold climate for part of the year? They said there's .3l of extra oil needed and cold temps won't affect viscosity or harm the engine.
      06-10-2023, 09:40 AM   #2
InspectorSeb
Drives: 2022 BRZ
There should be a thermostatic valve, so "over cooling" in a cooler climate shouldn't be a factor.
Unless you plan to push hard at HPDEs the factory cooler is sufficient IMHO.
      06-10-2023, 11:55 PM   #3
Dasky_spas
Drives: Bmw
Ya I would agree but this car spews off so much heat compared to many other cars, even when I'm not pushing it so I look at this as a way to prolong the internals.
Ceratec is going in next week with the oil change so was thinking to add the oil cooler then.
      06-11-2023, 07:13 PM   #4
Gossypiboma
Drives: 13' M3 6MT 18' M3 CS
Unless your causing oil temp warnings at the track you're waisting your money. Either way Do88 is the gold standard.
      06-11-2023, 08:35 PM   #5
mecheng77
mecheng77's Avatar
Drives: 2007 328i / 2014 M235i
  [0.00]
  [0.00]
No
      06-13-2023, 11:13 AM   #6
Joy15779
Drives: BMW M4 F83
yes. extremely happy. now running over 750 hp and oil tempi fixed around 90
BMW M4 F83 Stage 3/4 - Akrapovic Skat DP, NO OPF, eVenturi Intake, Okada Coils, Kratos Turbos EVO, Dodson 1000 Nm Clutch Dct - Mishimoto IC, Water and Oil Coolers - CP Carillo Pistons - Arrow Connecting Rods - Reinforced bearings - Halim Cazimi HCP Software 2.0 bar Turbo - XHPFlashTool for DCT Stage 3+
      06-17-2023, 06:50 AM   #7
Dasky_spas
Drives: Bmw
Thanks for sharing! What's the vehicle? For me, it'll be a tuned m850i, also around 700hp.
      06-18-2023, 03:32 PM   #8
pbonsalb
Drives: 18 F90 M5, 99 E36 M3 Turbo
If the m850i oil cooler is the same as on the m5, it is fine unless maybe you are tracking the car in hot weather at altitude.
