      12-18-2022, 10:17 PM   #1
M8CompSoCal
M8CompSoCal's Avatar
Drives: 2023 M8 Competion Coupe
Coming from Mercedes, I’m use to slightly pushing the break pedal a bit harder at a stop light to initiate break hold. Works great.
With my new M8, there’s a button that does the similar thing as my past Benz.
It works the same, but the only downside from what I’ve seen is that it constantly stays on and is annoying when pulling into a car space or my garage. I prefer the engine to do the work versus tapping my gas peddle to initiate the car to move forward in my garage, especially with 617 HP.
No I’m not bashing BMW, I was just used to soemthing on the Benz and if it doesn’t function the same, oh well, no sweat.
Can someone confirm if break hold can be activated by pressing the break pedal slightly harder like on a Mercedes or only in the way that I’ve been using it?
      12-18-2022, 11:53 PM   #2
Tejas1836
Tejas1836's Avatar
1710
Drives: 2023 F95 Workmaster 75
Brake pedal hold- holds for a couple of seconds
      12-19-2022, 04:24 AM   #3
HighlandPete
Drives: BMW F11 535i Touring
As long as users don't confuse Brake-Hold with the "Drive-off Assistant" you are describing above.
To the OP, you can switch Brake-Hold off and use the (timed out) Drive-off Assistant for situations where Brake-Hold is less suited.
      12-19-2022, 04:29 AM   #4
HighlandPete
Brake-Hold only works when switched on, then automatically activated by use of the service brakes.
      12-19-2022, 10:50 AM   #5
M8CompSoCal
Interesting. I will have to look at the drive off assistant
Yeah that’s what I thought. I definitely miss that feature but oh well, all good!
      12-19-2022, 12:50 PM   #6
Tejas1836
Tejas1836's Avatar
1710
This is what I am describing:
"Principle
The drive-off assistant supports driving off on uphill grades.
Driving off
1. Hold the vehicle in place with the foot brake.
2. Release the foot brake and drive off without delay.
After the foot brake is released, the vehicle is held in place for approx. 2 seconds.
Depending on the vehicle loading, the vehicle may roll back slightly."
      12-19-2022, 12:53 PM   #7
M8CompSoCal
Originally Posted by Onesie View Post
What’s the MB feature? I’m not familiar with how it works
https://m.youtube.com/watch?v=8LU3qJ4ZGJI
The key difference here is the break hold is only activated by pushing down the brake pedal a little bit more than usual. It’s not constantly running like when you have the button turned on like BMW does it.
      12-19-2022, 12:54 PM   #8
LogicalApex
Drives: 2020 BMW 530xe
2020 BMW 530xe  [0.00]
Another former Mercedes driver here.
The Mercedes way of activation just makes much more sense. There isn’t an “on/off” setting for it as it isn’t needed. You activate it by pressing the brake peddle harder, as you mentioned, when stopping.
BMW doesn’t do it this way. For BMW you first have to activate “Hold” under the shifter and it will be on until you turn it off again and is remembered between drive sessions. You then come to a stop and it will automatically activate the function. Pressing harder won’t influence its activation. I also don’t believe you can deactivate it with a tap of the brake pedal like Mercedes either. You have to tap the gas. I used to tap the brake on the Benz to prevent that jerky start feeling as the car removes the brakes and starts going from the gas pedal that can startle your passengers.
At least BMW “fixed” the turn signal stalk on the G30 compared to older models. That would have taken me a longer time to adjust to I feel.
      12-19-2022, 12:54 PM   #9
M8CompSoCal
"Principle
Driving off
Got it a little different than what I mean, but thank you for the clarification.
      12-19-2022, 12:56 PM   #10
M8CompSoCal
Precisely. Mercedes definitely implements it better, but it’s all good the AMG 53 GLE Coupe is what’s going to be used on the long road trips anyways or even the shorter trips where a lot of traffic might be involved, so it’s all good.
      12-19-2022, 01:09 PM   #11
EngineGoBrrr
Drives: 2022 X5 45e, 2023 X1
The MB way makes more sense. Though when I test drove the GLE I couldn't for the life of me get it to work. Either I pressed too light or too hard and never got it to engage. The salesman explained it to me and I attempted multiple times but to no avail. I'm sure once you get familiar with where the engagement point is then it would be a lot more convenient. I always have to turn off brake hold when parking in the garage for my cars.
      12-19-2022, 01:21 PM   #12
M8CompSoCal
Yeah, I pretty much have only been driving Mercedes. This is my first BMW. Like anything once you figure out the finesse it’s like clockwork. Super convenient and I love it. Same thing every time I go into my garage. I have to turn off break hold, which is a little annoying.
      12-20-2022, 03:32 AM   #13
Curious41
Curious41's Avatar
85
Drives: '14 GT3, '22 M3C, '25 i5
This is exactly why I don’t use auto brake hold in my car. What I find weird though is that some other BMWs I’ve driven function the same your Benz does including both pre-LCI and LCI G20 3 series. I wonder if it’s something that can be coded.
      12-20-2022, 06:05 AM   #14
HighlandPete
Are you sure you are not in situations where the Drive-Off Assistant is active/functioning? We've had the Drive-off Assistant from the E9x models of 3-series, no Auto-Hold until the G2x models.
Both the Drive-off Assistant and Auto-Hold use the service brakes.
      12-20-2022, 09:20 AM   #15
M8CompSoCal
If you find anything about this send me a DM. Thanks.
      12-20-2022, 03:02 PM   #16
LogicalApex
Interesting. I never have to turn it off pulling into my garage. Are you reaching a full stop going into the garage? For me it only activates when I reach a full stop.
      12-20-2022, 08:07 PM   #17
Curious41
Curious41's Avatar
85
Yea this was all with cars that had auto-hold. If I came to a stop, auto-hold would not turn on until I gave the brakes a bit of an extra push. In my M3, every time I come to a stop auto-hold activates.
      12-21-2022, 12:26 AM   #18
M8CompSoCal
Probably since I’m overly paranoid about getting in with this new car. Once I get use to the cars width it shouldn’t be a major issue, but still prefer the Mercedes implementation better.
Same here.
      12-21-2022, 12:42 PM   #19
SteveinArizona
Drives: BMW 530e
I think it is a matter of personal preference. Some folks prefer to never have an autohold on (I have a buddy with an X4; I urged him to try autohold and he hated it so he has left it turned off) and for them the BMW system works better; for those who like autohold (me included) I agree that the MB system appears to work better.
      12-21-2022, 02:25 PM   #20
HighlandPete
I suggest that is all in the pressure tolerances and brake feel of different models.
      12-22-2022, 11:46 AM   #21
snareman
Leave the gun. Take the Canoli.
snareman's Avatar
10782
Drives: 911 & X5 ///M60
My previous M4 was my first car to have this feature and overall I love it. I've never driven a MB to see how it is in comparison, but sounds like an interesting difference. Its interesting to see the little things that car manufacturers do similar but differently. I was looking at some Aston Martin's and their center screen is a dinky 8" compared to the 12" screen in my X3 and M8.
Current: 2025 X5 M60
Retired: 2023 M8 |||
2023 X3 M40 ||| 2021 M4 ||| 2018 M4 ||| 2017 M4 ||| 2014 435 ||| 2009 335 ||| 2007 335
      12-22-2022, 12:31 PM   #22
M8CompSoCal
Indeed. I’m not at a fanboy to any specific brand. I think each company does things well in their own respective ways. But as far as break old goes, Mercedes-Benz definitely takes to win.
