      12-16-2022, 11:42 AM   #1
Gruntly2006
Drives: Bmw 520d
A series of unfortunate events 🫣😂 help please, no power
I will give a quick run down.
Bmw 5 series 520d 2011
So I had battery charging malfunction error show on car, which cut out my power steering/lights and kindly popped my handbrake on on the dual carriage way. Long story short was battery, I began changing battery but car was blocking a drive so had to move mid battery change and stupidly shut the boot. Was relieved to find out could connect jump leads to the front to get power and pop boot. Was waiting on new battery so reclused boot on assumption I could do same again! Not sure if I may have touched chasis with jump lead when removing as have tried to do the same again now new battery has arrived, and absolutely nothing, no power what so ever and definitely a good connection as leads spark when attached. Any help or advice would be massively appreciated. Ps I’m a newbie so please go easy on me 😁
      12-16-2022, 06:11 PM   #2
Mavus
Mavus's Avatar
2478
Drives: E90 335i, F80 zcp
is there any way you can reach inside the trunk through rear seat and reach emerg release?
      12-17-2022, 11:30 AM   #3
Gruntly2006
Drives: Bmw 520d
I’ve drilled through the plastic panel in between the seats but can’t see a way of opening the boot from the inside doesn’t seem to have emergency release
