11-25-2022, 04:32 AM | #1 |
Rep 11
Four 8.5x19 M351 Wheels on a F06 xDrive legal?
I called up a parts dealer today to ask for a set of four 8.5x19 M351 wheels for my F06 650i xDrive and they told me that the 8.5 inch width version is only approved for the front axis and not the rear axis.
Knowing that a few of you guys have these rims, do you reckon that this model should be used that way or is it acceptable to use the smaller width version for the front and rear axis? Also, what (winter) tires are you using with your 351 wheels (dimensions)? Even better: BMW is not recommending the 351 for winter tires. They only recommend 18 inch wheels for winter tires. If I still want to use the 351 wheels for my winter and summer tires, can I use both in the same dimensions or would you recommend playing around with the width/height of the winter tires so that there's a bit more rubber in the end? The offiicial dimension are 245/40/19 front and 275/35/19 rear. Last edited by DownNOut; 11-25-2022 at 05:41 AM.. |
11-25-2022, 08:09 AM | #2 |
Rep 761
351, 8.5x19 wheels can be use front and back. That is called a "square" setup and is probably the best setup if you have Xdrive because all the wheels/tires are exactly the same in rolling circumference. That was also one of the "factory" options for your car, so your parts dealer is a moron.
Also, they will work fine with whatever "winter" tires you want to buy and I'd say stay with the square setup since it allows you to rotate the tires front to rear and side to side. |
DownNOut4.00 |
11-25-2022, 09:45 AM | #3 |
Rep 8,112
Ditto…and BMW offered 351 wheel style with two options from the factory (not sure how the parts people didn’t see that info in the database):
You can use 18”, 19”, or even 20” winter tires if that’s what you want. The 18” tires are recommended probably due to the higher sidewall and cheaper cost. But if you want to stay with the same wheel style that you use in the summer…or these are the wheels that are available to you…I say use them. If you want to use a different tire size than recommended in the owners manual for 19” tires…then use a calculator to determine which other sizes have the same overall diameter/circumference or is at least within spec so that you don’t screw up your transfer case or rub your suspension parts etc.
DownNOut4.00 |
11-25-2022, 09:53 AM | #4 | |
Rep 11
Just so that I'm absolutely sure: There's no 2 versions of the front axis 351 with different offsets or Einpresstiefen(ET) as the Germans call it? I can just buy 4 of these and be done with it (8.5x19 ET33)? https://www.leebmann24.de/bmw-alufel...117842652.html About the tires: Would you say that 255/40/19 are good tire dimensions for this square setup? Would you keep both summer and winter tires equal in dimensions? Yeah, it wasn't just one dealer who claimed that I had to go for the staggered setup 8.5x19 front and 9x19 back, and that made me suspicious. It's a 2013 F06 650i xDrive with the m-sport package and I just can't imagine that there wasn't an option to choose the same wheels in all four spots, especially since it is an xDrive model. They explicitly claimed that BMW hasn't certified that sqaure setup. Not sure if the square setup is only viable for the lower kW models. But then again, it could very well be that these dealers aren't the sharpest tools in the shed... |
11-25-2022, 10:04 AM | #5 | |
Rep 11
I assume that the ideal tire dimesions for the 8.5x19 ET33 wheels are 245/40/19, at least that's the front wheel specs that the dealer gave me for the staggered setup. Don't know if they would choose something else for the square setup. Here's what the tire calculator gives me: https://www.calculator.net/tire-size...9&y=12#compare The 255/40/19 has a diameter that is 1.17% bigger than the 245/40/19 diameter. Would you say that this is acceptable or is this already enough to put unnecessary stress on the wheel bearings etc.? |
11-25-2022, 10:50 AM | #6 |
Rep 8,112
You can go to one of the online part databases sites, enter the last 7 digits of your VIN, then go to the WHEEL diagrams and see the information for yourself. I input my VIN which is a 2015 650iX GC (has M sport pkg) that came with 20” Style 373 wheels…and the wheel diagram lists both the square & staggered style 351 wheels when I click on that diagram:
Here’s two popular sites: For winter tires…I would go for the thinner width tire if I had to choose since a thinner wheel cuts through snow better which allows the tread to reach the road surface better.
11-25-2022, 12:27 PM | #7 | |
Rep 761
11-25-2022, 01:34 PM | #8 |
Rep 2,928
I echo Walt's suggestion on using all-season tires year round unless you live somewhere where the extra bite of winter tires is an absolute must. Walt lives in Philadelphia and I live in Denver, so neither of us is a stranger to snow. I have never had dedicated winter tires on any car in the 50 years I have been driving. I just use Michelin Piot Sport AS4+ year-round.
11-26-2022, 03:14 AM | #9 | |
Rep 11
Here are the results I got after entering my own VIN: https://www.realoem.com/bmw/enUS/sho...diagId=36_1655 https://bimmercat.com/bmw/en/search/...E4/ECE/36_1655 It's still a bit of confusing for me... Both sites tell me that I should I use two 9x19 for the rear and two 8.5x19 for the front axis, or am I interpreting it wrongly? My last seven digits are D148820 just in case I mistyped something in the queries above. Is that conclusive evidence against or for the square 8.5x19 setup? About the 255/40/19 tires: Since I live in Switzerland, winter tires are a must, so there's no way around it here. I found a great deal on 4 almost brand new 255/40/19 tires so if they are compatible with the 8.5x19 rims and my F06, I'd go that route even if the smalle tires might be a bit better for winter conditions as you mentioned. They're probably not 500$+ different... Also, I noticed a "pro" seller selling the square set of the 351 wheels here: https://www.werksraeder24.com/bmw-mi...0001198-2.html Upon contacting them with my VIN, they declined and told me that these wheel's aren't compatible my my car. As you can see, they list F10, F11, F12,F13, but somehow, the F06 is a step too much for these... weird... Last edited by DownNOut; 11-26-2022 at 03:27 AM.. |
11-26-2022, 05:06 AM | #10 | |||
Rep 8,112
But the fact that their data appears…means that even if they weren’t ordered for your car originally…they still are a selection you can opt for after the fact. If they didn’t fit or work for your car, the database (when using your VIN) would have either grayed the item out in the diagram and the part nbrs would NOT be listed in the part nbr database below the diagram. Quote:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 11-26-2022 at 05:32 AM.. |
Walt White Coupe245.00 |
11-26-2022, 08:17 AM | #11 |
Rep 761
Qsilver7,
Thanks for that update. You said: The biggest difference between the 245/40/19 & 255/40/19 tire is approx 4mm height difference. That difference is probably for "regular" tires. I suspect that truly "snow" tires may have an even greater height difference. |
11-26-2022, 09:00 AM | #12 | |
Rep 8,112
I will caution…you do take chances when you go outside the recommendations made by BMW. Sometimes you may win…sometimes you may lose. Be prepared.
11-28-2022, 07:40 AM | #13 |
Rep 121
If there's a real winter I'd go with 225/50/18 size, the more narrow tire the better it run's on the snow.
And if playing with staggered 19" wheels 225/45/19" front/255/40/19" rear work's nicely! Here is mine with staggered 19" summer set. |
