10-07-2022, 09:25 AM | #1 |
Rep 3
2007 M6 E63 6-speed Manual
Asking $31,500 - I have had this listed on M5 board for a year or so, posting here to cast a wider net. I am in Charlottesville, Virginia. I work in Reston, so I can show it at either location or anywhere in between. I bought this car in 2019 to bring to Germany, with 17 miles of unrestricted Autobahn between my house and office, it was an amazing ownership experience. I planned to sell it before coming back, but ended up returning to VA on short notice in 2021 due to COVID drama. It was stored (indoor, climate control, CTEK the whole time) from November 2021 until July 2022. I have driven it a couple times a week for the last few months but would like to open up some garage space for my DD before winter. 2007 BMW M6 Coupe, 6-speed manual V10, 122,250 miles. No accidents, Meticulously maintained, no issues or imminent service, rod bearings and other recent service history listed below. Secondary cat/resonator delete with x-pipe. Evolve Stage 2 tune: 93 octane, 8500rpm redline, VMAX delete. Rock chips in the front bumper, otherwise cosmetically great for its age/miles driven. Painted (black) carbon fiber roof wrapped with protective carbon fiber vinyl. Comfort access (2x FOBs), soft close doors, HUD, Individual Sound, merino leather with carbon fiber trim. Leather dash has some "shrinkage" that has improved with leather balm treatments. The rear end makes some noise when cold but goes away after a few turns (noise started after switching to Redline + friction modifier, hasn't been annoying enough to switch back to the BMW fluid). 121k - Leaky A/C fill valves replaced, system evac'd/recharged 121k - Oil and filter change 121k - Replaced Throttle actuators 120k - New front oil pan and transmission covers installed 119k - Replaced fuel filter and o-ring seal 118k- Installed stainless steel brake lines, brake and clutch fluid replaced 117k- Secondary cat and resonator bypass installed with x-pipe - primary cats and stock mufflers remain 117k- Oil and filter change 116k- Transmission and differential oil change (Redline oils) magnetic diff plug installed 115k- Replaced connecting rod bearings, Replaced VANOS high pressure line, Repaired stripped oil pan threads (work performed by MW Performance in Rockenhausen, Germany) 112k- Replaced 10x spark plugs, 4 ignition coils, cabin air filters, engine air filters, 2x beauty cover grommets, 2x airbox clips and Cleaned MAF sensors 111k - Replaced 4 tires and 1x ignition coil 110k- Alternator replaced, coolant replaced Included in sale: original chrome kidney grills and side grills original exhaust section 2 car cover Replacement rear brake rotors, pads and wear sensors Extra BMW TWS oil New BMC air filters CTEK charger/maintainer spare front wheel with TPMS sensor miscellaneous small spare clips, seals, etc Laptop with cable and NCS expert/TIS/etc preloaded Last edited by Flitzr951; 10-07-2022 at 04:49 PM.. |
