03-08-2021, 03:47 AM | #1 |
Rep 52
M6 GC Air-conditioning fail question/troubleshooting.
Good Morning peoples,
I drove my M6GC to dinner Friday night the air-conditioning was working fine. No issues, nice and cold. Went to dinner for about 2.5 hours, jumped in the car started it and it now blows hot air, not ambient temperature. Like proper hot as if the heater is on! I wound the temp up to 26 degrees and it didn't change still hot, back down to 16. Still hot. Does anyone have some troubleshooting ideas for me. I figured if it was loss of gas I would notice it over time not instantly like this. It's as if the AC is stuck on heat or something. Thank you in advance Chris |
03-08-2021, 07:58 AM | #3 |
Fueled by Recycled Dinosaurs!
657
Rep 1,183
Drives: F06 M6
I haven't had an issue with mine yet, but I have worked on several automotive AC systems. It has been my experience that a slight drop in pressure could result in the AC clutch not engaging so what mikerx5 says makes sense and is an easy low cost step.
03-08-2021, 11:05 AM | #4 |
Rep 632
Have you checked what the outside temperature indicator is saying. If that is damaged the AC system will not function properly. If it is indicating 50C the sensor is shorted. If 40C the sensor failed open or wiring broken.(check these at startup).
F06 M6 Grand Coupe CP
TinCanSailor656.50 chrisveal24.50 |
03-17-2021, 07:22 PM | #7 |
Rep 52
Had the car looked over by BMW, turns out the compressor and the evaporator need replacing.
To me i struggle to see how the A/C was working fine, I turn the car off. Have dinner, turn the car on, not working. Either way it is getting fixed up. |
03-18-2021, 03:32 PM | #8 |
Rep 754
04-05-2021, 08:52 PM | #9 |
Rep 52
Hi guys, thought I would give an update. Yes, BMW is doing the A/C under warranty. I am waiting on parts to come from Germany, due to Covid it takes a little longer to get to Australia. BMW identified the compressor and the evaporator need replacing.
Now the funny part! As quick as the A/C died, it is now working again!! Frosty cold now issues, as of yet touch wood. So this lead me to believe its not the compressor or the evaporator and maybe something like a sensor Wiggins out?!?! Any gurus on here to help me out on this one? |
07-18-2021, 03:40 AM | #10 |
Rep 52
So this bloody gremlin just came back today, the A/C has been working great ever since it randomly started working. Took it for a hard drive and had a few drinks, jumped in the car after a few hours and bam, no A/C just like before.
Any advice, I am possibly leaning to the temp sensors playing up. |
07-18-2021, 05:50 AM | #11 |
Rep 119
A diagnostic check from a competent vehicle air con specialist should be able to tell.
I recently lost cold air and fortunately, like a few others, it just needed a recharge. The mobile air con company I used was well recommended and carried on board a rather costly Denso machine which only needs to connect to the high pressure valve. During the process the machine did pick up a couple of small blockages which it cleared. Could it possibly be a blockage? Only a check will tell. |
08-28-2021, 06:21 AM | #12 |
Rep 52
So I have troubleshoot and found that I need to replace the compressor.
Does anyone have a clue as to how to get that thing out, it's hidden right in there! I accessed it from the bottom to trouble shoot but to get it out, if need to remove the steering arm. Cheers Chris |
08-28-2021, 07:36 AM | #13 | |
Rep 754
08-28-2021, 07:58 AM | #14 | ||
Rep 52
mikerx5468.00 |
08-30-2021, 02:17 AM | #15 |
Rep 52
Before I go down the rabbit hole with this compressor, can anyone tell me where the signal 12V comes from to engage the cloth on the compressor? As the tech could get a reading in the signal wire,
Cheers Chris |
08-30-2021, 03:31 PM | #16 |
Rep 632
Here are the fuses. Be sure to check the refrigerant pressure. If it is too low, the compressor clutch wont engage. The fuses are behind the glove box.
good luck
TinCanSailor656.50 |
09-04-2021, 08:05 AM | #18 |
Rep 52
Does anybody know where the A/C compressor relay is. Every time I look it keeps coming up with that big one in the boot next to the battery. Seems very large for a A/C relay.
09-04-2021, 09:56 AM | #19 |
Rep 632
The AC compressor magnetic clutch is switched by the Junction Box Electronic module on pin 7 of the 47 pin connector (A34 1B). The A34 is located behind the glove compartment.
You con check for power to the clutch at connector X13-1B This is the connector to the magnetic clutch (see Y1) You can also check the resistance on the clutch coil at this point to assure continuity through the coil.
09-06-2021, 03:12 AM | #20 | |
Rep 52
09-06-2021, 01:23 PM | #21 |
Rep 632
The wire for the clutch is the purple and green wire (pin 11) on the connector. See the X13*1B connector pins arrangement.
09-07-2021, 03:00 AM | #22 | |
Rep 52
Thanks again. |
