07-27-2020, 12:27 PM | #1 |
Rep 57
Sos call system failure
Hey guys, I just installed a mmi andream box in my 6 series f13 and it works great, the only downside is i have to use the aftermarket mic. This morning it worked great, no errors nothing. Turned the car off for a couple hours and when started it again i got the sos error, anyone ever dealt with it? Any solutions? Thank you
07-28-2020, 04:12 AM | #3 |
Rep 57
I didn’t remove any unit at the top, not sure which one you refer too, i did press the sos button and it did work, i got a call back, it’s just the error popping when turning the ignition on.
07-28-2020, 06:17 AM | #4 |
Rep 3,072
I have the bimmertech version. What do you mean aftermarket mic? The kit does not include a mic, just power, video and wife cables.
I do think that the system is a bit wonky, sometimes won't start, and wireless phone call are terrible. I just found out there are software updates, will install and see how things improve
My Car Photo Blog: http://carfisheye.blogspot.com/ Last edited by mjposner; 07-28-2020 at 06:54 AM.. |
07-28-2020, 12:45 PM | #6 |
Rep 57
I found a guide online, I think I found the issue, I installed the mic that I shouldn’t.
Copy paste d) SOS CALL System Failure i. Check Quadlock is sitting properly on the Headunit ii. Occurs when microphone tap cable is installed and switch 8 not in correct position. iii. Occurs when microphone tap cable is installed but not required |
07-28-2020, 02:09 PM | #7 |
Rep 57
Removed the mic and all good now, hope it lasts, but what I noticed is that i was getting sound trough bmw Bluetooth, i was connected to the mmi and the car at the same time, in the manual says to disconnect from the car, if i do that i get no sound. Do you guys use an auxiliary cable for sound? Did you connect the auxiliary cable in the arm rest auxiliary?
07-28-2020, 08:10 PM | #8 |
Rep 3,072
Per manual do not use bluetooth through factory system, set media type to aux (no cable).
