      04-25-2020, 03:58 PM   #1
GostaFly
Drives: 2014 M6 CP
Telematics Battery - Where is it?
I need help. I am getting SOS Emergency call system malfunction in my 2014 M6 F12 convertible. I figured i would try to replace the battery in the telematics box as a first step however i cant find the damn thing. Does anyone know where it is on an f12 convertible? I have taken the floor apart and left side carpet in trunk and didnt find it. Real OEM shows in trunk area but cant find this thing.
      04-25-2020, 06:48 PM   #2
GostaFly
Drives: 2014 M6 CP
Found it. You have to remove rear seat back.
      04-25-2020, 07:14 PM   #3
arucano
arucano's Avatar
2014 BMW M6 GC  [10.00]
I thought that battery is only used if the main car battery is disabled in an accident to make an emergency call.
F06 M6 Grand Coupe CP
Sapphire Black Metallic
The drive is the destination
      04-26-2020, 04:12 AM   #4
Qsilver7
Qsilver7's Avatar
You found it...but the location is also shown if you use the TIS website. The location (and FUB aka functional description) was found by typing “telematic control unit” into the search bos...the TCU is listed as A231 in the schematics:
      04-26-2020, 09:35 AM   #5
Rsnk60 M6
Drives: 2016 BMW M6 GC
Update
You need to go to dealer so they can update system , I had something last month.
M6 Daddy
      04-26-2020, 12:44 PM   #6
RagtagXMASTER
RagtagXMASTER's Avatar
135
Drives: 2013 M6
I know there is a big issue with these on the light bmw suvs. I think they attempt a software update first. If that fails. I think they replace the unit. If you are out of warranty. Code out the sos function. That is if you do not care about the sos function.
      10-16-2024, 07:34 PM   #7
Qsilver7
Qsilver7's Avatar
Originally Posted by M5FirstEdition View Post
Brother, any idea where i can find it in my grand coupe? I have done the same, took off all rear carpets and no luck. I would appreciate any insights. Thanks
On the GC…A231 is located on the left side of the trunk…see diagram below:
