08-28-2019, 02:37 PM | #1 |
![]() ![]() 81
Rep 268
Drives: M6 GC
Battery Warning message
Does anyone get this message pop up? Ive made sure my battery is fully charged with a top of the range trickle charger (all 5 lights so OK) - is this standard or does it suggest my battery is draining?
08-28-2019, 03:05 PM | #2 | |
![]() ![]() ![]() 269
Rep 582
I went to BMW dealer to get a new battery 950cca 105ah $270,the swap was very easy and I registered it with the Carly app its a 30 to 40min job |
08-28-2019, 04:19 PM | #3 | |
![]() ![]() 81
Rep 268
Drives: M6 GC
08-29-2019, 04:37 AM | #4 | |
Rep 582
08-29-2019, 04:14 PM | #6 | |
![]() ![]() 81
Rep 268
Drives: M6 GC
08-29-2019, 04:15 PM | #7 |
![]() ![]() 81
Rep 268
Drives: M6 GC
08-30-2019, 02:43 AM | #8 |
![]() ![]() ![]() 265
Rep 406
Drives: 2021 G30 M550i
Can be much simpler than a worn-out battery... I have seen this in near new car after for instance extensive detailing with high power amp/sound system on, and repeated lock/open action because of comfort access and key in pocket (leave inside for detailing)... If this occurs repeatedly without for no obvious reason, then you may have a battery issue...
08-30-2019, 05:54 PM | #9 |
![]() ![]() 31
Rep 96
This has more likely due to a failing comfort access door handle. Are you experiencing any issues with either door?
2017 X5M (LBBlue/Aragon) 2000 Z3M Roadster (EstB/Black) |
Flying Ace5066.50 NorthCountryGuy1685.00 |
08-31-2019, 02:30 AM | #10 |
![]() ![]() 81
Rep 268
Drives: M6 GC
08-31-2019, 02:34 AM | #11 | |
![]() ![]() 81
Rep 268
Drives: M6 GC
08-31-2019, 05:47 AM | #12 | |
![]() ![]() ![]() ![]() ![]() 286
Rep 731
How will this effect battery life ?? |
09-04-2019, 08:23 PM | #13 |
![]() ![]() 31
Rep 96
that's a good sign. The comfort access system uses both door handles as radio antennae and trunk to triangulate where the key is. If one goes bad (which they do more often than not)... it will start to drain your battery. Symptoms are... no detection at a specific door handle. Repeated attempts to lock or unlock. The car locking or unlocking on it's own as you walk near a side of the car. The gas filler locking over and over.
09-04-2019, 09:26 PM | #14 | |
Rep 582
![]() But I do have comfort access problems it seems I have to pull the handle for the doors to unlock instead of just touch, the front passenger side won't lock the car I touch the top ribs and nothing so I have to look into that, so your saying this can cause battery drain? I have 2 more spots to check ,I have my exhaust valves 12v piggy backed into one of the fuses from the rear fuse box I need to find a key switched fuse,I think this is my main problem My Valentine 1 Savvy plugged into the obd2 port its unlikely this |
09-09-2019, 11:43 AM | #15 |
![]() 66
Rep 184
Passenger Comfort access door handle was the reason why it came up for me.
They disconnected and ordered me a new one. Message is gone. |
Flying Ace5066.50 |
09-23-2019, 08:52 PM | #16 |
![]() ![]() 31
Rep 96
same for me
09-27-2019, 11:36 AM | #17 |
![]() ![]() ![]() 5067
Rep 11,907
Update?
22 Phytonic/Coffee X5 45e (Retired)
10-01-2019, 06:58 PM | #18 |
Rep 582
I do have a comfort access problem with my passenger side door handle it doesnt respond to lock,I can only open it if I fully engage the handle but the sensors behind the handle aren't responding.I dont use this handle much so its not troublesome ,I was thinking this was my battery issue but it wasn't
It turned out to be my Meistershaft exhaust controller was on a constant hot and even know it wasn't being activated it was still draining power to make the message pop up after 3 days sitting So I located a fuse(thanks to a forum member) in the rear fuse box that is switched from ignition on and piggyback fused off of that, there is only 4-5 fuses that are switched in the whole box,so after 7 days sitting no message this fixed my problem ![]() |
General Lee81.00 |
10-07-2019, 04:06 PM | #19 |
![]() ![]() 81
Rep 268
Drives: M6 GC
10-10-2019, 09:26 PM | #20 |
Rep 11,907
Chalk another issue to brexit!
12-26-2019, 10:09 AM | #21 | |
![]() ![]() ![]() ![]() ![]() 304
Rep 709
![]() I thought of disconnecting the battery for about 10 min. And see if the message comes back. Does all the memories stay or do I have to set them again. |
General Lee81.00 |
12-26-2019, 10:16 AM | #22 |
Rep 731
Dealer had mine for almost 3wks, at first they blamed the tracker and then took up my advice on checking the comfort access, surprise, surprise it was the CAS (control access module) messing with the comfort access, all in all they replaced the battery and starter motor and alternator, should have took my advice, but that would be listening to the customer !!
General Lee81.00 |
