      03-18-2016, 03:12 AM   #1
bmwstve
Drives: BMW X6, MHD Stage 2
Small piece of cardboard fell into the heater vent. What to do?
Today as I was cleaning my car of documents/papers on the dashboard
A small piece of card roughly the size of a calling card fell into the heater vent in front of the dashboard/windshield.
Pls see photo below.
I tried to get it but it totally went in!!
What should i do??
Will it damage the car?
      03-18-2016, 07:04 AM   #2
overcoil
Drives: M235i 6spd
Wouldn't give it a second though.
      03-18-2016, 07:18 AM   #3
Chihuahua
Chihuahua's Avatar
5387
Drives: E30 329iS, E65 Alpina B7
Is it making noise? If not I wouldn't worry about it at all. I removed the AC evaporator from my E30 once, inside of the case I found portions of two business cards, a paper clip, and 2 AAA batteries.
      03-18-2016, 08:07 AM   #4
bmwstve
as of now it doesn't seem to make any noise. I'm just concerned that it might get lodged onto something or worse get burned due to heat of engine/wiring etc.. cause i don't know how deep it fell
      03-18-2016, 08:16 AM   #5
overcoil
Drives: M235i 6spd
I think things falling into those vents are so common they're designed with that in mind.
I'm not sure the design of the blower fan and filter in these cars, doubt they're channels are designed that items would drop into the filter housing, but you could access the HVAC filter and see if the card appears.
      03-18-2016, 08:43 AM   #6
Polo08816
Drives: 2014 335i M Sport
What should i do??
You should turn the heat on the max temperature setting and see if you can just burn the cardboard away.
      03-19-2016, 07:57 PM   #7
BEM-S4
BEM-S4's Avatar
Drives: Dinan M235, Dinan Sport Wagon
If you want to pull the vent just grab it, it pulls right out. Can remove the cardboard then pushes back in place. Pulled mine to run wires for proclip phone mount. Very very easy.
2022 Macan S
2016 F31 328i xDrive Sport Wagon
2006 E46 330ci ZHP Convertible
      03-24-2016, 01:52 AM   #8
bmwstve
How did you do this? I cant even fit half of my finger to pull the vent out..
      03-24-2016, 07:38 AM   #9
BEM-S4
BEM-S4's Avatar
Not a single vent, pull the entire assembly with both vents and center buttons. Just grab the trim up by the screen and give it a good yank. Check the DIY thread I posted a proclip install and linked to vent removal if you need more detailed instructions with photos.
2022 Macan S
      03-24-2016, 07:50 AM   #10
overcoil
Drives: M235i 6spd
I thought the OP's vent in question was at the base of the windshield not forward facing central dash vent ?
      03-24-2016, 08:17 AM   #11
BEM-S4
BEM-S4's Avatar
Oh shit, if that's the case disregard my input. Thought we were talking about the center vents, must have missed something somewhere. Sorry for the confusion.
For the vents up by the windshield, I would use a vacuum or shop vac and tape the end so there is only a small opening to maximize suction then run it up by the vent and see what happens. I would then assume I got the piece of cardboard and not give it a second thought.
