      07-23-2014, 02:09 PM   #1
greggtash
Drives: f90 m5
2013 BMW 650i CONVERTIBLE/COUPE (MEGAN RACING COILOVERS/DAMPER KIT)
BIMMERPOST / Classifieds
Asking Price:
None
Item Interest
FOR SALE IS MY MEGAN RACING EURO STREET SERIES COILOVERS TO ADJUST YOUR 2012 AND UP F12/F13 6SERIES CONVERT/COUPE DAMPER CONTROLS AKA RIDE HEIGHT OR STANCE!!!
RETAILS FOR $999
ASKING FOR $499
CONDITION USED*
GOT RID OF MY 650 SO HAVE NO NEED FOR THEM ANY LONGER
ALL PHOTOS ARE MINE!
GO AS HIGH AS YOUR WANT OR AS LOW AS YOU WANT!
-GREG
CALL OR TEXT ME (213)300-7080
CALIFORNIA RESIDENT.
Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 levels of damper force adjustment, separate spring perch height and shock length adjustment allowing you to retain full suspension stroke and to fine tune your suspension characteristics. These damper kits are then perfectly matched with front and rear Pillow Ball upper mounts, including camber plates integrated with the upper Pillow Ball mounts on strut-type suspension applications.
Compression and rebound settings are easily adjusted through a single damper adjustment knob which is built-in at the top of the damper mount for easy access. Adjustments are simple to tune according to your style of driving and desired comfort level whether you are a professional certified mechanic or an automotive enthusiast with amateur mechanical skills. All of our dampers are capable of handling a +2kg/mm or -2kg/mm change in spring rates to further tune your suspension to your desired handling characteristics.
      07-28-2014, 07:19 PM   #2
Zack G.
Extraordinaire
Zack G.'s Avatar
Drives: '14 650i MSport CP
Do the back seats need to be removed to install these?
Tags
coilover kit, drop, f13, f13 6 series, slammed stance low
