08-16-2018, 08:43 AM | #1 |
Rep 269
Drives: ///M6 GC
2024-1 North America NEXT map
2024-1 North America NEXT map is now available.
Note: I don't sell FSC codes. =============================================== MAP file part 1 here >>>: https://drive.google.com/drive/folde...-X?usp=sharing MAP file part 2 here >>>: https://drive.google.com/drive/folde...lP?usp=sharing =============================================== >>> Fix download quota exceeded <<< 1: Select link with the file which you are trying to download - when the web page loads, login with your Google account 2: Right click on file & select make a copy 3: Navigate to your google drive, My Drive folder & locate the file you want to download 4: Right click on file & click on download 5: When you finish downloading, delete the file from your My Drive folder then go to the trash & delete it forever. Repeat steps above for the 2nd map link. >>> Saving map files|folders to USB Flash drive <<< - 64GB or bigger capacity required - FAT32 file system 1. Free software to format large capacity USB Flash drives to FAT32 >>>: http://ridgecrop.co.uk/download/fat32format.zip 2. Free software to format large capacity USB Flash drives to FAT32 >>>: https://rufus.ie/en_US/ - Boot selection = Non bootable - Partition Scheme = MBR - File system = Large FAT32 =============================================== 1. Map files|folders must be saved on the root of the USB Flash drive 2. When viewing contents of the USB Flash drive, you should ONLY see the files|folders below. 3. If they are inside another folder or if there are hidden files (added by using a MAC\OSX) then it will not work. =============================================== From wt888 Many drives are seen by the PC as "Local Drive" in "My computer", as if they were backup hard drives, not portable memory sticks. After inserting the USB drive into your car and getting a message to update it, an error message then says to insert the USB drive, and you can't get past it. The solution is actually to use a USB FLASH drive that is recognized as "USB Drive" in "My computer". If it shows up as Local Drive, your car won't see it as a USB drive either. The solution is to get another USB Flash drive. =============================================== USB Flash drive I use: https://www.amazon.com/Patriot-Super...tronics&sr=1-1 =============================================== TIP: Buckle driver side seatbelt to prevent iDrive from going to sleep during the upgrade =============================================== >>> Create DE.FSC file which is required by the FSC Generator <<< Requirement: E-Sys & ENET cable Prerequisite: disable all firewalls, Antivirus. Set Ethernet to DHCP (not static). EDIABAS 7.3.0 installed 1. Connect ENET cable to OBD port 2. Connect ENET to laptop Ethernet port 3. Wait until ALL lights in instrument cluster\dash turns off 4. Turn on Ignition, press START button (DO NOT step on the brakes, engine does not have to be on) 5. Wait until Ethernet has yellow exclamation ! Open command prompt & type ipconfig 6. Ensure you have 169.254.xxx.xxx IP address for Ethernet 7. Wait 2 minutes 8. Launch E-Sys 9. Select Connect 10. Select appropriate Target (based on I-Level) Note: Don’t use _DIRECT 11. Select Connection via VIN 12. Select Connect 13. Click Expert Mode 14. Select FSC Extended 15. Diagnostic Address (hex) = 0x63 16. Click Identify 17. Application Number (hex/dec) – 0xDE 18. Upgrade Index (hex/dec) – 0x1 19. Scroll down & select StoreFSC 20. Select Add to the batch button (>>) 21. Select Read 22. Select Save 23. Use the following naming format when saving FSC file. XXXXXXX_000DE001.fsc Note: XXXXXXX is the last 7 of your VIN =============================================== Uploaded all the files I use here >>>: https://drive.google.com/drive/folde...Nl?usp=sharing =============================================== Free software to extract the compressed files & folders >>>: https://www.7-zip.org/ =============================================== BMW_CIC_FSC_Generator.zip download location >>>: https://mega.nz/file/PFsHHYLY#pYF4sv...wzhvVvINin5Rnk >>> Generating FSC code for map updates - BMW_CIC_FSC_Generator.exe <<< All credit goes to the software developer(s) 1. Extract BMW_CIC_FSC_Generator.exe from the ZIP file 2. Open BMW_CIC_FSC_Generator.exe 3. Select OK to download Lookup.xml file (computer needs internet access) 4. Select OK then close and open the program again 5. Select NBT then use Browse button to select FSC file created with E-Sys & ENET Map type = Next Region = NORTH AMERICA Maps = ROAD MAP NORTH AMERICA NEXT 2021-1 Suggestion: check mark on Lifetime Select Generate button =============================================== >>> Determine Region & Map sequence code <<< Note: requires HxD application: https://mh-nexus.de/en/hxd/ Region & Map sequence code - located in the 1st folder of the map files File path = 1\INFO_MAP_NANT_#####\Info_Map.imp North America NEXT: Last edited by BadSeed; 03-18-2024 at 08:24 PM.. |
31
ooshnoo889.50 3rdCoastBMW18.00 8bits0.00 550xiGuy0.00 Neuera09278.50 F31MGUY11.00 dadaabmw34.00 DrPhant0m13.50 kamiiza0.00 x-m4n148.00 yifuuX17.00 Kraftwerk AG460.00 JT8Diesel8.50 desmat36.50 TinCanSailor633.00 Kolianovskyi87.00 Silververtu231.00 walmark85.50 PrideRock870.00 AZ535i164.00 COUWK21.00 oln0881.50 CHECKERED123.50 TheUltimateDrivingManiac835.00 mness60.00 happydude139.50 Margas17.50 Philipp535i1.00 fe7565556.50 CPSI903.00 |
08-16-2018, 09:36 AM | #2 |
Rep 632
Thanks for the info. Looks great. Can you please pm the link.
F06 M6 Grand Coupe CP
08-16-2018, 04:20 PM | #3 |
Rep 3,071
link to me too please
08-16-2018, 06:49 PM | #4 |
Rep 269
Drives: ///M6 GC
08-17-2018, 03:07 PM | #5 |
Rep 1,703
Drives: 2014 428i and 2018 X5
Can you PM me the link too?
Thanks!
___________________ 2014 F32 428i M-Sport 2018 F15 M-Sport |
08-20-2018, 03:53 PM | #12 |
Rep 269
Drives: ///M6 GC
08-20-2018, 08:06 PM | #13 |
Freude am Fahren.
835
Rep 1,287
Drives: F15 X5 xDrive35i
I would not mind to get a link too Thanks!
Freude am Fahren.
08-21-2018, 08:15 AM | #14 |
Rep 269
Drives: ///M6 GC
08-21-2018, 10:33 AM | #16 |
Rep 269
Drives: ///M6 GC
08-21-2018, 01:02 PM | #18 |
Rep 269
Drives: ///M6 GC
08-22-2018, 10:46 PM | #20 |
Rep 269
Drives: ///M6 GC
