Login
08-16-2018, 09:43 AM | #1 |
![]() ![]() 111
Rep 254
Drives: ///M6 GC
2021-1 North America NEXT map
2021-1 North America NEXT map is now available.
Note: I don't sell FSC codes. =============================================== Part 1 here >>>: https://drive.google.com/drive/folde...-X?usp=sharing Part 2 here >>>: https://drive.google.com/drive/folde...lP?usp=sharing =============================================== >>> Fix download quota exceeded <<< 1: Select link with the file which you are trying to download - when the web page loads, login with your Google account 2: Right click on file & select make a copy 3: Navigate to your google drive, My Drive folder & locate the file you want to download 4: Right click on file & click on download 5: When you finish downloading, delete the file from your My Drive folder then go to the trash & delete it forever. Repeat steps above for the 2nd map link. >>> Saving map files|folders to USB drive <<< - 32GB or bigger capacity required - FAT32 file system - Free software to format large capacity USB drives to FAT32 >>>: http://www.ridgecrop.demon.co.uk/ind...?guiformat.htm 1. Map files|folders must be saved on the root of the USB drive 2. When viewing contents of the USB drive, you should ONLY see the files|folders below. ![]() 3. If they are inside another folder or if there are hidden files (added by using a MAC\OSX) then it will not work. TIP: Buckle driver side seatbelt to prevent iDrive from going to sleep during the upgrade =============================================== If you have E-Sys & an ENET cable, follow the steps below for generating your DE.FSC file. Prerequisite: disable all firewalls, Antivirus. Set Ethernet to DHCP (not static). EDIABAS 7.3.0 installed 1. Connect ENET cable to OBD port 2. Connect ENET to laptop Ethernet port 3. Wait until ALL lights in instrument cluster\dash turns off 4. Turn on Ignition, press START button (DO NOT step on the brakes, engine does not have to be on) 5. Wait until Ethernet has yellow exclamation ! Open command prompt & type ipconfig 6. Ensure you have 169.254.xxx.xxx IP address for Ethernet 7. Wait 2 minutes 8. Launch E-Sys 9. Select Connect ![]() 10. Select appropriate Target (based on I-Level) ![]() Note: Don’t use _DIRECT ![]() 11. Select Connection via VIN 12. Select Connect 13. Click Expert Mode 14. Select FSC Extended ![]() 15. Diagnostic Address (hex) = 0x63 16. Click Identify ![]() 17. Application Number (hex/dec) – 0xDE 18. Upgrade Index (hex/dec) – 0x1 ![]() 19. Scroll down & select StoreFSC 20. Select Add to the batch button (>>) ![]() 21. Select Read 22. Select Save 23. Use the following naming format when saving FSC file. XXXXXXX_000DE001.fsc Note: XXXXXXX is the last 7 of your VIN =============================================== Uploaded all the files I use here >>>: https://drive.google.com/drive/folde...Nl?usp=sharing =============================================== Free software to extract the compressed files & folders >>>: https://www.7-zip.org/ =============================================== >>> Generating FSC code for map updates - BMW_CIC_FSC_Generator.exe <<< All credit goes to the software developer(s) 1. Extract BMW_CIC_FSC_Generator.exe from the ZIP file 2. Open BMW_CIC_FSC_Generator.exe 3. Select OK to download Lookup.xml file (computer needs internet access) ![]() 4. Select OK then close and open the program again ![]() 5. Select NBT then use Browse button to select FSC file Map type = Next Region = NORTH AMERICA Maps = ROAD MAP NORTH AMERICA NEXT 2021-1 Suggestion: check mark on Lifetime Select Generate button ![]() =============================================== >>> Determine Region & Map sequence code <<< Note: requires HxD application: https://mh-nexus.de/en/hxd/ Region & Map sequence code - located in the 1st folder of the map files File path = 1\INFO_MAP_NANT_#####\Info_Map.imp North America NEXT: ![]() Last edited by BadSeed; 09-12-2020 at 11:16 AM.. |
16
08-16-2018, 10:36 AM | #2 |
![]() ![]() ![]() 117
Rep 352
Thanks for the info. Looks great. Can you please pm the link.
F06 M6 Grand Coupe CP - 'E39 530I 5sp
Sapphire Black Metallic/Black - Black/Black The drive is the destination ![]() |
08-16-2018, 05:20 PM | #3 |
![]() ![]() 545
Rep 2,877
link to me too please
My other rides: 1965 Chevrolet Corvair Corsa and 2007 Porsche 911s My Car Photo Blog: http://carfisheye.blogspot.com/ |
08-16-2018, 07:49 PM | #4 |
![]() ![]() 111
Rep 254
Drives: ///M6 GC
08-17-2018, 04:07 PM | #5 |
![]() ![]() 637
Rep 1,258
Drives: 2014 428i
Can you PM me the link too?
Thanks!
![]() ___________________ 2014 F32 428i 8AT M-Sport |
08-20-2018, 04:53 PM | #12 |
![]() ![]() 111
Rep 254
Drives: ///M6 GC
08-20-2018, 09:06 PM | #13 |
Freude am Fahren.
![]() 618
Rep 1,200
Drives: F15 X5 xDrive35i
I would not mind to get a link too
Freude am Fahren.
08-21-2018, 09:15 AM | #14 |
![]() ![]() 111
Rep 254
Drives: ///M6 GC
08-21-2018, 11:33 AM | #16 |
![]() ![]() 111
Rep 254
Drives: ///M6 GC
08-21-2018, 02:02 PM | #18 |
![]() ![]() 111
Rep 254
Drives: ///M6 GC
08-22-2018, 11:46 PM | #20 |
![]() ![]() 111
Rep 254
Drives: ///M6 GC
