      04-27-2025, 12:34 AM   #1
MrGCarmonaM6
Drives: BMW M6 F06
New Battery, Dash Full of light, then Off?
I had a message that stated battery discharge. I drove the car for a few miles and decided to buy a new OEM battery. I didn't immediately change the battery and the car sat for one day without starting or driving the car. When I started the car, I had numerous lights on the dash appear. The abs, the brake light, the air bag light, the steering light, check engine light, and traction control light were all on. I replaced the battery and registered it with the car. When I turned the car on, all the dash lights were still on. I decided to try and take it for a drive and when I put the car in drive, the car turned off. Does anyone have any ideas of what could be wrong? Or any solutions? Thank you in advance!
      04-27-2025, 07:47 PM   #2
L337TurboZ
Drives: 2014 BMW M6 Gran Coupe
Have you checked for any DTC's? That would be helpful to know what codes are set.
      04-27-2025, 08:13 PM   #3
TinCanSailor
Fueled by Recycled Dinosaurs!
TinCanSailor's Avatar
896
Drives: F06 M6, F10 550i, E93 335i
Date code on the battery and was it fully charged when it was installed. There is a natural loss on batteries when they sit for a long time.
      04-27-2025, 08:55 PM   #4
MrGCarmonaM6
Drives: BMW M6 F06
L337TurboZ yes a bunch of them ...
      04-27-2025, 08:58 PM   #5
MrGCarmonaM6
Drives: BMW M6 F06
TinCanSailor just bought the OEM battery a week ago and the date code is 02/25
      04-28-2025, 09:41 AM   #6
TinCanSailor
896
Excellent, good to see they didn't try to sell on that was older. It may be under charged. Do you know if it went on a trickle charger before going in the car?
      04-28-2025, 10:03 AM   #7
TinCanSailor
896
Have you been driving the car? This should help charge the battery if you do not have a charger. Also, have you cleared the codes? Typically after 3 drive cycles without a fault the CEL would clear itself. Now that you have captured your codes you can clear them after getting the battery voltage/charge up to spec and they go on a test drive to see if they reoccur. If they comeback I would suggest rechecking your ground connection and verify they battery type that was programmed.
      05-05-2025, 07:37 PM   #8
MrGCarmonaM6
Drives: BMW M6 F06
TinCanSailor I needed a new door handle comfort touch was bad so blew fuse #2 in glove box, replaced door handle and fuse, everything fixed
      05-05-2025, 07:38 PM   #9
MrGCarmonaM6
Drives: BMW M6 F06
L337TurboZ I needed a new door handle comfort touch was bad so blew fuse #2 in glove box, replaced door handle and fuse, everything fixed
