| 10-28-2024, 06:05 AM | #1 |
Rep 12
Bmw 118i low coolant warning
Hey guys,
Back with another question/problem ![]() Today in the morning I got a warning for low coolant (pic attached). I then stopped the engine, started it again and the message disappeared. I also had a look at the engine coolant level, and it does seem low (pic also attached). There is no sign of leakage around the engine, or the tubes and neither on the ground, so I'm not sure why the level is so low or if this is even a normal occurrence and the coolant needs to be re-filled once every few years. My car is a 118i from 2017 with ±138.000 km. Recently (±2 months ago) I did a service where the distribution cap was changed because oil was leaking from a seal around the distribution cover and BMW service has not mentioned any coolant leakage back then. Could it be that some coolant was lost in the process while they changed this piece? The service DID mention some "antigel" (I think translated it means anti freeze / coolant) change that was not needed, and the total price paid was less than the original quote. Last edited by Fausto; 10-28-2024 at 07:28 AM.. |
| 10-28-2024, 07:28 AM | #3 |
Rep 12
Update: I went to a mechanics store and bought this type of coolant, the guy said it's for all vehicles including BMW and I can top-off safely, do you guys think it's OK?
| 10-28-2024, 04:43 PM | #4 |
![]() 1252
Rep 1,664
If you never added the coolant I guess it should be fine it went down in 7 years.
If there's a small leak it can be difficult to notice: https://f20.1addicts.com/forums/show...&postcount=363. You can either have the car inspected for coolant leaks specifically or start with a top-off if you haven't done that recently and see if you need to repeat that any soon.Regarding the coolant type it's apparently safest to use the BMW genuine coolant. A universal coolant won't ruin your car immediately but it might cause some harm/damage over time, depending on what it actually is. If that coolant you have has a brand name you can look it up. If it even does not it should be a cheap substitute to avoid, probably. Also see the manual, page 251. ![]() |
| 10-28-2024, 04:54 PM | #5 |
![]() ![]() ![]() ![]() 2430
Rep 812
I can't remember exactly the max and fill lines but your expansion tank photo does look low. It's possible the service might have lost some coolant and they didn't do the bleed procedure.
If you're losing coolant and you can't find a leak or residue of one check for coolant in your oil. If so, have a pressure test done on the cylinders.
| 10-29-2024, 03:59 AM | #6 | ||
Rep 12
I found the correct one - BMW Frost Protection Frostox HT-12 - but it takes more than a week to get here and I use my car constantly now, and I really wanna top off asap. Quote:
| 10-29-2024, 04:13 AM | #7 |
![]() ![]() ![]() 188
Rep 516
There is some 4dcl missing. Dont mix if it doesnt fit. You can drive around as long as there is coolant present (visible)- if there is upcoming coolant change near. If not in frosty climate you can add some 2 dcl of distilled water instead.
| 10-29-2024, 05:13 AM | #8 | |
Rep 12
Also, do you have any idea how many liters of coolant mix does the 1 series 118i take? The manual barely provides any information about coolant change, unfortunately. I found the following coolants:
I found mixed results for the correct coolant, with some mentioning the HL-12 is for most BMW models after 2018 (mine is 2017). How do I found out which one to buy for my car model? |
| 10-29-2024, 05:24 AM | #9 |
Rep 516
Id say some 8-10 litres. Cant comment on coolant type, do some googleing. For as long as there is some in the tank you can drive. Once you get the coolant delivered just fill it non-diluted (if changing it in a few months). I dont know about water, in our language and market there was always destilled one. Maybe demineralizedvis the same. Im not even sure Bmw prohibts tap water (as drawn on coolant bottles)
| 10-29-2024, 08:24 AM | #10 | ||||
![]() 1252
Rep 1,664
I read (well, awhile ago) no BMW part would take more than a day to be delivered in Germany.Quote:
) for "replacement, not initial filling". The manual says: "Your Service centre can provide details of which additives are suitable.". You can ask them other questions as well. They shouldn't charge for that. ![]() Quote:
![]() It should be fine to use the no name coolant pre-mixed you bought for a short time before complete replacement, I believe. That's what it's for. |
| Bookmarks |
