| 08-27-2024, 01:52 PM | #1 |
Rep 12
Bmw key fob!!!
As stated need a helping hand with my key fob, non of the buttons work to lock or unlock the car, the central locking button in the car works perfectly for all doors same as opening with the key blade all doors open as should, i have had a new key made and programmed by a local automotive locksmith woth still no joy i dont know what software he uses but he said there are no faults in the car 🤦 i have also changed the diversity antenna with no luck checked all the fuses i have also checked the loom running to the diversity antenna with no joy
Anyone else had this problem?? I need to fix this 😂😂 Located south wales uk I don't have access to ISTA unfortunately Car is a 2013 bmw x1 e84..... |
| 08-27-2024, 02:29 PM | #2 |
![]() 1252
Rep 1,666
Insert/replace the fob battery.
Westside Guy10262.00 |
| 08-27-2024, 02:30 PM | #3 |
![]() ![]() ![]() 369
Rep 424
Definitely sounds like a battery problem.
| 08-27-2024, 02:45 PM | #4 |
Rep 12
| 08-27-2024, 02:46 PM | #5 |
Rep 12
| 08-27-2024, 03:41 PM | #7 |
Rep 12
| 08-27-2024, 04:32 PM | #10 |
Rep 12
| 08-28-2024, 09:57 AM | #11 |
Rep 661
so checked wiring diagram .. antenna is in the diversity...
diversity is located in the trunklid?! if Yes .. check Harness for brohen wires in the rubbergrommet between trunklid and body.. wire for key signal is blue/white |
| 08-28-2024, 03:21 PM | #12 | |
Rep 12
Thanks for looking for me, have also checked the wiring and all seems fine no broken wires also checked blue and wire with a tester and when oressing buttons on the fob it picks up and tester starts beeping so all fine there |
| 08-29-2024, 02:25 PM | #13 | |
Rep 12
Thanks |
| 08-30-2024, 11:34 AM | #14 | |
Rep 12
UPDATE!!!! after playing around with a launch diagnostics today this is what comes up anyone have an ideas of these?? Would it be pointing at car battery being weak?? |
| Bookmarks |
