      04-24-2024, 12:22 AM   #1
mariodix98
Sweden
Drives: BMW 640d 2012
Hello i have an 640d and i have some fault codes that says Boost pressure actuator VNT. The car has bad boost up to ca 2500rpm and after that it goes like crazy.
I think it’s the electronic wastegate on the small turbo. Do someone know what it can be?
The codes:
292200: boost pressure actuator (VNT): position sensor in the boost pressure actuator defective or undervoltage.
27B900: exhaust pressure upstream of the turbine, plausibility: difference between measured and calculated exhaust pressure to low.
      05-10-2024, 05:16 AM   #2
mariodix98
Sweden
Someone???!!
      05-20-2024, 07:48 AM   #3
General.Massacre
South Africa
15
Drives: 2013 F13 640d MSport
It will be your Small Turbo boot solenoid. i think its the rear actuator, i would recommend getting a Vacuum hand pump, and testing the Solenoids, there are 2 large ones on the left side of the motor when you looking at it.
and 2 smaller ones near the back of the motor by the firewall, also check the vacuum hoses are not broken/perished.
There is a bunch of hoses that go from the Wastegates also. its a complicated system to investigate.
      05-23-2024, 07:52 AM   #4
mariodix98
Sweden
Thanks but i fixed it last week. It was the electronic turbo actuator/wastegate. I replaced that and now it works
