      04-07-2024, 04:25 PM   #1
09E60 N54
09E60 N54's Avatar
Drives: 2009 E60 535i
misfire or sudden gear change
I’m having a problem when I’m at high rpm and I gear change, it almost feels like I’m slipping for a second. I am F.B.O and stage 2+. I havnt gapped the spark plugs so I tuned it down to stage 1+ and still happens but not as much. Brand new spark plugs and coils. Still wondering if it’s the spark plugs and would a misfire cause it to change gear weird at high rpm?
      04-08-2024, 09:59 AM   #2
RockCrusher
Drives: BMW 2024 M8 Competition Coupe
Is the CEL on and if so are there any misfire error codes?
A more transitory misfire condition can have the CEL flashing and the CEL might not remain on after the misfires have stopped.
I have encountered -- 2nd hand -- issues arising from the wrong plugs being used in engines. Just because a plug compatibility chart shows Plug X is the same as a factory plug is no guarantee this is truly the case.
You should first confirm the gaps are correct before installing new plugs.
Instead of misfires are you perhaps inadvertently/unknowingly hitting the rev limiter?
      04-08-2024, 03:55 PM   #3
09E60 N54
09E60 N54's Avatar
I wouldn’t think it’s the plugs and I havnt had a misfire code while on stage 1+ but still jerkyness on high rpm in high gears. In stage 2+ I was getting misfire code on cylinder one but sometimes went away and sometimes I had to clear it.
      04-08-2024, 04:09 PM   #4
09E60 N54
09E60 N54's Avatar
It’s also a very weird gear change but don’t know how to explain it
