      12-23-2023, 09:35 AM   #1
bimmer456
Drives: 340i
IP rated key fob
Since our phones are IP rated why not make key fobs that are water resistant should be easy to just put a gasket in the housing?
      12-23-2023, 10:05 AM   #2
alex2364
alex2364's Avatar
3754
Drives: 2020 M4 ZCP / 2023 X3 M40i
2020 BMW M4  [9.69]
2023 BMW X3 M40i  [9.75]
Why would BMW want to deal with warranty claims on water submerged keys?
      12-23-2023, 11:34 AM   #3
KevinC
your average JAMF
KevinC's Avatar
Drives: '21 M2 Comp, '19 Golf R
The question isn't "why not?" but "why?"
'21 M2 Comp
'19 Golf R
      12-23-2023, 04:35 PM   #4
fe7565
fe7565's Avatar
Drives: 2012 BMW 328i N26
I believe it has an o-ring type gasket inside protecting the circuit board. Does it work ( if enough water is splashed on it)? No...
Help each other: if you manage to fix your issue (especially with help from this forum), don't be a d*ck and disappear. Follow-up by posting the solution so you can help others.
      12-24-2023, 08:19 AM   #5
chris719
Drives: '08 M Roadster
My F8x keyfob has gone through the wash 3 times and still works.
      12-24-2023, 12:43 PM   #6
No one
Drives: F21 118i
BMW sells cars, not key fobs. And when it comes to a key fob replacement, reportedly, it costs a fortune already. In my experience BMW OEM accessories are often of poor/crappy quality compared to counterparts.
      01-17-2024, 06:34 AM   #7
fe7565
fe7565's Avatar
nestcozy
You must be in politics! Had to re-read it three times and I am still confused
LDT5231.50
      01-17-2024, 07:04 AM   #8
No one
Drives: F21 118i
Originally Posted by fe7565 View Post
nestcozy
Spot on! It's a spammer projecting (using AI?) my preceding post you didn't bother to read even once.
