| 06-20-2023, 09:36 AM | #1 |
![]() 26
Rep 84
N54 knocking sounds... please advise
Can someone please lend their ear and listen to this weird noise my 535 is making. Its happening while driving and idling, and it goes in and out. The noise is loudest towards the end of the video. No codes are showing on Protools. The noise sounds like it's coming from the driver side of the engine bay, under the air filter.
| 06-20-2023, 09:44 AM | #2 |
#buildnotbought
20210
Rep 6,452
If you have a manual, then it sounds like your dual mass flywheel is going out.
It could also be the front pulley. That's also a vibration damper (vulcanized rubber on metal, the bond can tear)
| 06-20-2023, 10:08 AM | #3 | |
![]() 26
Rep 84
... the backdrop is, I put 5gallons of 87 in the tank, then topped it off with 10 gallons of 93 after I realized it was the wrong gas becuse the idling changed as I was filling up. Car drove fine that night. I didn't push it or anything. The noise started the next day? Do you think it has anything to do with the lower octane fuel (I assume with the mix it ended up ~91octane)? ...if not, are either of those things you mentioned very hard to fix? Any tips on diagnosis? I'm a diyer... Last edited by Maxmil982; 06-20-2023 at 10:18 AM.. |
| 06-20-2023, 11:28 AM | #4 |
#buildnotbought
20210
Rep 6,452
I can't comment on the fuel issue.
If that causes the knocking, your engine is probably toast... Replacing DMF is probably too complicated if you have to ask, but it depends on your skillset and situation of course. I assume you have access to a lift and a transmission jack? Regarding diagnosis, use an engine stethoscope and pinpoint the source of the knocking. That is the normal way to start a job like this.
| 06-20-2023, 11:28 AM | #5 |
![]() ![]() 3067
Rep 6,534
I can't watch your video/sound right now but based on your text description, I wonder if it's the noise I'm thinking about.
Does the noise go away the moment you touch the gas or when you say it happens driving, even with the gas and cruising around it does the noise? EDIT: Nvm, I just heard the noise now. Last edited by TheMidnightNarwhal; 06-20-2023 at 06:24 PM.. |
| 06-20-2023, 11:43 AM | #6 |
![]() ![]() ![]() 7487
Rep 13,403
((5x87)+(10x93))/15=91 so the octane should not be a problem unless your boost is beyond stock. Even then 91 probably supports a little more boost.
I would think fatal rod knock would not come and go. I would investigate the pulleys as suggested above. Last edited by pbonsalb; 06-20-2023 at 06:44 PM.. |
tracer bullet6003.00 |
| 06-20-2023, 05:55 PM | #7 | |
![]() 26
Rep 84
Anyway, sounds like main pulley, since there was that rattling noise. Is that a straightforward fix? |
| 06-20-2023, 06:07 PM | #8 |
![]() 10313
Rep 2,765
Drives: 2026 X5 | 2020 M4 CS
This is one of the handiest diagnostic tools you can get. Perfect for locating noises and cheap.
https://www.powerbuilt.com/products/...cs-stethescope |
| 06-20-2023, 06:52 PM | #9 |
Rep 13,403
Have to get a better idea of where the problem is first. These cars can leak oil all over the front of the motor. Is yours oily? Fix that. While the belt is off spin the pulleys and feel them for wobble. Replace any that are loose or noisy. Fix the leaks. The U shaped oil cooler hose leaks at the upper crimp and drips down and that gets flicked around by the fan and belts. The oil cooler to oil filter housing gasket leaks. The oil cooler housing to oil cooler lines o-rings leak. The oil filter housing to block gasket can fail. The valve cover gasket can leak but does not usually make a mess on the front of the motor. The crank pulley seal can leak but that usually drips downwards.
Install a crank pulley guard once it is all cleaned up and fixed. If your crank damper is bad, the job is bigger. If your crank seal is bad, the job is much bigger. Make sure you do have all the belt and that it did not shred and part of it go through the seal into the motor. |
| 06-20-2023, 07:26 PM | #10 | |
![]() 26
Rep 84
| 06-21-2023, 07:03 PM | #12 |
![]() 26
Rep 84
You were right, I jumped the gun... its not the crank pulley. AC compressor pulley exploded. I dropped the underpan and all these pieces fell out (see pic). There's no oil leak. I changed the OFHG, o-rings and VC gasket last year under regular maintenance... I guess the pulley just wore out and took a shi. I'm researching how to swap it out now, but do you have any tips or things to look out for, when changing it out?
| Bookmarks |
