      03-13-2023, 10:22 AM   #1
xito_a
Drives: 2014 650xi GC
650i oil pan for cheap
My oil pan get ruined and i need to buy a new one but not trying to spend a few grand on it. Is there any comparible oil pans that are cheaper or does it make sense to find a used one online? or should i just bite the bullet and buy a new one from the dealership?
      03-13-2023, 10:59 AM   #2
Opie55
Drives: '15 650i Convertible
Although I have not looked, I doubt there are any aftermarket oil pans. You could probably get a used one as long as all the seals etc. get replaced. But I would not buy it from a dealer in any event. I can't speak for Canada, but in the US it is typically way cheaper to buy an expensive part online, even though you are often buying from a dealer that sells online. Plug the last 7 places of your VIN into RealOEM.com and find the right part, then Google the part number and you'll find lots of sellers.
      03-13-2023, 11:01 AM   #3
Opie55
And just out of curiosity, how did your oil pan get ruined? It's pretty protected under there.
      03-13-2023, 11:10 AM   #4
Opie55
I just looked, and the upper oil pan is about $1,000 US, although some eBay seller has them for $815. But that's the big part the drive shaft goes through. If all you need is the bottom lower cover, that is about $440 US. If you need both, it will be about $1,400 US.
      03-13-2023, 01:11 PM   #5
D'Mann
Drives: 2015 650i GC - M Sport
ECS tuning has OEM for around $426.00:
https://www.ecstuning.com/b-genuine-...n/11137570691/
      03-14-2023, 06:24 PM   #6
xito_a
by chance do you know which is connected to the drain plug (my model is 2014 650i xDrive GC) Essentially my drain pan isn't ruined yet however the plug is stuck and is most likely stripped and every mechanic i took it to told me that i would 90% need a new oil pan if they attempted to get it out. So now i took it to the dealer for them to try and if the pan comes out damaged im going to order the part online.
      03-14-2023, 06:30 PM   #7
Opie55
Luckily for you, that is just the lower pan.
      03-14-2023, 06:39 PM   #8
xito_a
thanks sm man! dealership quoted the pan at 1500 cad today and wouldn't be able to install for a week if my pan is indeed ruined. Saved me nearly $750 and probably a few days without my car since im just going to take it to my main mechananic
      03-14-2023, 06:52 PM   #9
xito_a
sadly doesn't fit for my car but found an oil pan that does fit and wanted to double check if i did this right?
real oem for lower pan shows this and im assuming it is the first part number "11137570694"
(link: https://www.realoem.com/bmw/enUS/sho...67#11137570694)
then found this on ecs tuning: https://www.ecstuning.com/b-genuine-...n/11137570694/
would that be the correct part for the lower oil pan that has the drain plug?
      03-15-2023, 08:08 AM   #10
Opie55
Yes, that is the correct part.
      03-17-2023, 04:56 AM   #11
SWFLf10
SWFLf10's Avatar
If the plug is really stuck and you want to reuse the pan instead of getting a new one, they should be able to drill out the old plug after removing the pan from the engine. Even if they get a little off center they can always use a timesert to repair the hole.
I had to install a timesert in my pan on my N55 due to the previous shop overtightening the plug and damaging the threads.
Copyright ©2000 - 2025, vBulletin Solutions Inc.
