01-12-2016, 05:58 PM | #1 |
Rep 41
Wheel spacer recommendation please
Just traded in my beautiful Estoril blue 328i Msport (memories ?) for the new love of my life 650i Msport but I don't like way the wheels look sunk into the car.
I don't have plans on wheels at this time so what brand/size spacers would you guys recommend to get the wheels flush? |
01-14-2016, 03:03 PM | #3 |
Rep 676
Drives: 2015 M6 Gran Coupe
I got 10mm all around.
01-14-2016, 11:38 PM | #6 |
75
Rep 245
I have run spacers on a few BMW's with mixed results. I had spacers on my new M5 and the steering wheel vibrated like crazy above 90 mph and had to take them off. Hope you have better luck.
01-15-2016, 12:10 AM | #7 | |
Rep 41
Were you running spacers with aftermarket wheels, coilovers and/or any other upgrades? I surely don't want those results since it would defeat the purpose of the ride quality bmw is known for. |
01-15-2016, 10:22 AM | #8 |
Rep 676
Here's a recent photo taken by my SA at McKenna BMW
I have the KW HAS kit installed too I need a car wash so I haven't taken any nice photos yet |
01-15-2016, 01:19 PM | #9 |
Rep 282
Don't ///M cars have different suspensions and wheels and offsets? I would think the pacer thickness would be different for an m car vs a 640 or 650. That said, what manufacturers are prefered for spacers?
01-15-2016, 05:07 PM | #10 | |
Rep 6,075
As far as offset the major issue is the rear wheels. Regular 6 er M sport wheels(373) have 44mm offset on rear wheels which is 10 mm less than M5 wheels (i.e. 343M - M5) and 25 mm less than M6 wheels (i.e. 343M - M6) For front wheel there is no major issue since 373 has 33mm, 343m -M5 has 33 mm and 343M M6 has 32 mm; however they all have different width...
01-15-2016, 05:23 PM | #11 | |
Rep 90
Anyone else running spacers on an M6 with OEM? |
01-15-2016, 05:57 PM | #13 | |
Rep 6,075
I believe you can run 10-15 mm spacer all around M6 with OEM wheels...
01-20-2016, 10:23 PM | #14 | |
75
Rep 245
01-27-2016, 04:19 PM | #15 |
Rep 676
It's probably because you didn't have Hub Centric spacers. They need to be minimum of 10mm to be hub centric. Otherwise there will be vibrations.
01-29-2016, 06:53 AM | #16 |
Rep 48
01-29-2016, 11:17 AM | #17 |
Rep 135
Drives: 2015 M6 GC
I'm wanting to go with 10mm all around with a 305/30/20 tire on the rear anyone see any problems with that on factory 601's
01-31-2016, 11:11 AM | #18 |
Rep 676
if it isn't lowered, then 305 with 10mm spacers should be fine. it may rub if lowered though.
01-31-2016, 12:43 PM | #19 |
Rep 135
Drives: 2015 M6 GC
01-31-2016, 10:53 PM | #20 |
75
Rep 245
My car had 10mm/12mm hub centric spacers from Macht Schnell. I even swapped them front to back a couple of times and no luck either way. I guess I could try another brand but have a feeling it won't matter.
02-06-2016, 01:07 PM | #21 |
Rep 676
Hmm that's very odd. I have the Macht Schnell 10mm front and back. No vibrations at any speeds.
