      06-14-2015, 12:14 AM   #23
2007 to 2016 M6 Cab
Drives: 2019 M2 Competition HS
Originally Posted by brad850csi View Post
Is there much room on the inside as far as clearing suspension components or other things is concerned? Michelin make a 335/30/20 you see
There was no issue with clearing the suspension componenets with how Manu from Aritso Collection Designed the rims ( These are a very Agressive custom design ... Manu can be contacted if you are interested in the same set-up from Aristo Collection - http://aristocollection.com/ ... meaning he was not too keen on giving away the ET) ... there was a slight rub on the inner rear wheel well liners and a simple plastic body rivet was enough to get the liner out of the way and gave us a half inch of clearance in total from the inner liner and suspension components ... (Actually Mercedes did this as they dealt with Manu when he was the designer/partner at DPE for my last M6 and S63 AMG (Yeap ... even my last 2007 M6 was worked on by the PArts Manager at Three Point Mercedes with Manu Gill) ... Here in Victoria all the German brands are under one ownership ... BMW had an issue with the 325's actually fitting and had little faith in Manu, but Manu now from Aristo Collection and Sean from Three Point worked on my cars for rims hand in hand before, and now for the 2016 M6 worked on the rim design, tire selection and fitment and knew it would work (Manu himself has the M6 GC and worked on another Client M6 Coupe - but with 20s on them, and he used those cars to custom fit my 21s and fit the 325 rears with no rub on suspension components ... so the 2016 M6 was moved to Three Point to have the Rubber and Rims Mounted and the Rear Wheel well liner sucked back for clearance before it went to detail)
I now have 1100 km on it, thanks to a 3 year old birthday party in Nanoose Bay (300 km round trip) and even at highway speeds over dips in the highway at 120 km/hour and 2 kids in the back and gear - NO RUBBING
As far as the 335 goes ... I differ the discussion to Manu
Current Garage:
2019 M2 Comp, 2019 GLC 63 AMG , 2017 GLS 63 AMG, 2015 S63 Amg, 2008 John Dheer Gator XUV
Past Cars:
2016 M6 Cabrio, 2015 GLK 250 Bluetec, 2007 M6 Cab, 2011 S63 Amg, 2008 S450, 2006 330xi, 1998 Z24, 2002 Chev Suburban
      06-14-2015, 12:19 AM   #24
2007 to 2016 M6 Cab
Originally Posted by M6-Coupe View Post
I'm not sure if 245 front / 325 rear is a good setup (I have a feeling that your will experience under-steering now), but for sure 245 tire on 9.5" means you must be very careful to avoid getting curb rash while your rear rims are protected by wide tires. Please share your driving experience with this setup. Also if you don't mind would you share the rear rims ET?
ONE THING I DID NOTE: with the 245s runflats up front, there was no shake in the steering wheel on slight ruts in the highway like had been on my 2007 M6 with 255/30ZR20s with runflats ... ride was smooth as well ... now this lack of shimmy/shake could be the total re-design of the current M6 .. but then again I do not have a 255 or 265 to compare too ... and I never drove the care on the stock tires and rims.
Anyone else have an opinion or experince with the shimmy/shake of the steering wheel ... my buddies with the last generation Corvette complained about similar issues with their runflats
Current Garage:
Past Cars:
      06-14-2015, 12:25 AM   #25
2007 to 2016 M6 Cab
Originally Posted by BimmerGuy25 View Post
Just to double check, your running 325 30 21's in the rear correct? Cause I want to order that same exact size for my rear but was really trying to see if it will fit and not hit the fender liner. It seems like you even have room to lower it as well. Cause I have KW V3's I want to close that gap, not going to lower the rear much just 0.5 if possible. What you think?
Yes we are running Pzero 325/30ZR21 runflats on the rear .. yes there is room to lower with how Manu from Aristo has set up the rear rim, however we did need to suck the inner liner in away from the wheel a little
Current Garage:
Past Cars:
      06-14-2015, 12:33 AM   #26
M6-Coupe
M6-Coupe's Avatar
1439
Drives: F92 M8C Coupe
And for sure you know that stock tires are not run flat? Both Michelin and Pzero tires are tubeless. All current M cars are the same... any specific reason you chose run flat?
Current : 2024 F92 Black Sapphire M8 Competition- ZF8
Gone : 2020 F92 Black Sapphire M8 - ZF8
Gone : 2018 F80 Mineral Gray M3 Competition - 6MT
Gone : 2016 F82 Austin Yellow M4 Competition - 6MT
      06-14-2015, 12:37 AM   #27
2007 to 2016 M6 Cab
I run a lot of highway miles to and from work ... first patient is 8 am ... can't be late due to a flat or blow out ...
Current Garage:
Past Cars:
      06-14-2015, 04:15 PM   #28
BimmerGuy25
Drives: '14 X6M '14 M6 '15 C300
Thank you for the information. I will make adjustments to my rear fender liner before we mount on the tire/rim. Because like I said, I want to lower the car enough to close that gap. If it wouldn't be too much to ask, would you mind sharing your front and rear offset?
      06-14-2015, 04:59 PM   #29
2007 to 2016 M6 Cab
You are welcome re the information. The Offset, however, is something you will need to take up with Manu at Aristo collection as this was the first one he did with this set up for 21s and 325 on the rear.
Current Garage:
Past Cars:
      06-15-2015, 04:05 AM   #30
BimmerGuy25
I definitely will, thank you!
