01-08-2015, 11:30 AM | #1 |
Rep 35
Recommended tires for 640i XD GC?
I am just replacing my 373M 20" wheels with runflats for the 343M M5 20" wheels and need recommendations on tires. My goal is to make my Alpine white GC look aggressive, sporty, the tires be not too expensive and they be all-weather tires as I live in Seattle. I also don't want to mess the rotation of the tire too much so that it affects the speedometer/drivetrain more than needed. Some of the searches I have done on here have revealed:
Hankook R-S3 rears: 285/35/20, fronts: 245/40/20 (Can't remember the brand) Rears: 285/30/20, Fronts: 255/35/20 Any ideas based on the above info is greatly appreciated! |
01-08-2015, 01:34 PM | #2 |
Rep 6,274
You have to make sure the total size of wheels be the same or very close...
The size of wheel is calculated this way: Rim diameter + 2 side walls where the side walls are related to the size of tire. The first number shows how wide your tire is in mm. The second number is aspect ratio which is the ratio of side walls. For example: 285/35/20.... the width is 285 mm or 11.22" The side wall is 11.22 x 35/100 = 3.92" The total wheel size = 20 + 3.92 + 3.92 = 27.84" if the new wheel (rear rim+tire) is larger than this size your actual speed is more than what you see on speedo. If the new wheel is smaller than this size, your actual speed is less than what you see on speedo. BTW, your speedo normally shows a bit more than actual speed
Current : 2024 F92 Black Sapphire M8 Competition- ZF8
Gone : 2020 F92 Black Sapphire M8 - ZF8 Gone : 2018 F80 Mineral Gray M3 Competition - 6MT Gone : 2016 F82 Austin Yellow M4 Competition - 6MT Gone : 2013 F13 Sakhir Orange M6 -7DCT |
01-08-2015, 02:49 PM | #3 | |
Rep 35
01-09-2015, 05:01 AM | #4 |
Rep 68
Use this http://www.rimsntires.com/specspro.jsp and it will do all of the calculations for you
01-10-2015, 02:45 PM | #6 |
Rep 3,971
I agree 100%. They don't handle as well as the OEM run-flats in the dry (warm), but they are doing just fine here in Chicago this winter and the ride is much nicer. Still think I'm going to put the RFTs back on this spring/summer.
01-16-2015, 05:44 PM | #7 |
Rep 35
Thanks for the advice. I think I am going to go with the Bridgestone Potenza 255/35 and 285/30.
There shouldn't be any issues with switching the TPMS from my 373M to 343M wheels, should there? |
01-16-2015, 06:25 PM | #9 |
Rep 3,971
Just making sure you are aware those are summer tires. It shows you are in Seattle - not sure where in Seattle, but I thought you guys occasionally got bad stuff there?
01-16-2015, 09:24 PM | #10 |
Rep 35
01-17-2015, 09:05 AM | #11 |
Rep 3,971
Ahhh, you had neglected to mention which Potenza you were getting
I only saw the RE050, S001, and RE760. Two things 1. BMW has changed the recommended tire size for that wheel I believe. I don't know if they changed the wheel itself or what -but I noticed that the width went up 10mm at somepoint. 2. Can I ask what is making you go with the Bridgestones? I was not aware of them (they don't show in the 373 size), but when I click on the survey results at tirerack, they are ranked 10th whereas the Conti DWS are ranked 1st.
01-17-2015, 09:36 PM | #12 | |
Rep 35
07-06-2015, 01:03 AM | #14 | |
Rep 63
What made you go 285 over 295 on the rear? Some of the guys here did it but in the UK, we have a legal limit with wider tyres where it should not stick out beyond the wheel arch. Thanks, |
