04-23-2024, 07:33 PM | #1 |
'14 M6 GC Comp Owner
22
Rep 54
Side Window Deflectors?
Looking for a high quality, durable side window deflectors for F06. Anybody know of a reputable source?
I used to think these look odd on the cars / trucks but now I see the practicality side of it. Extreme summer heat is around the corner and I’d like to crack my windows to let out the interior heat. -DK
[Owned] 2015 BMW 640i xDrive Gran Coupe
Driving 2014 BMW M6 Gran Coupe Comp Still on the hunt for '14 - '15 M6 GC Comp or '20+ X4M Comp in San Marino Blue with White Interior |
04-25-2024, 07:11 PM | #3 |
Rep 7,588
Plus the owners manual warns not to use them because they can impeded the anti-trap- function…plus our windows are always moving up/down as the door is opened/closed.
If you’re still inclined, don’t let us discourage you…give them a try to see if they work without any issues. Nothing ventured, nothing gained.
05-07-2024, 02:45 PM | #4 | |
22
Rep 54
05-07-2024, 02:57 PM | #5 |
Rep 72
Vehicle makers especially BMW strive to design their vehicles with optimal aerodynamics, and the addition of third-party gadgets is often detrimental in many ways. not just with wind deflectors, but a plethora of other additions.
05-08-2024, 09:00 AM | #6 | |
Rep 7,588
As mentioned by D'Mann...the f06/f12/f13 six series has frameless doors...which closes onto a gasket...there's nothing to attach the deflectors to on these models. The windows are designed to drop down a smidge when the door is opened, then raises back up into the gasket when closed...this creates a better seal against wind noise, dust, & water infiltration. A car door that has a frame, has a rubber gasket that easily protects both sides of the glass...a frameless door does not...thus this design that lowers/raises the glass adds this sealing feature. This makes an add-on window deflector not very compatible with the door's operational design...regardless of the pinch-protection. The only place to mount the deflector is on the gasket around the door....unless you attach the deflector to the drip rail. You'd also have to figure out if the window drops down far enough to clear the deflector when the door is opened and closed. Some pics of the frameless door and the gasket around the door's opening as examples of why deflectors probably won't work well on this model:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 05-08-2024 at 10:58 AM.. |
05-12-2024, 08:14 AM | #8 | |
Rep 7,588
Do you feel that your door gaskets are weak? You may have to answer your own question based on how your 6 series is aging. I had a 2013 and sold it in 2020…and still have a 2015 and I don’t hear any wind noise or see degradation of the gasket. As far as wind noise from the windows…the purpose for the drop action when the door is opened is that the window lowers when the door is opened, then rises back up and is sandwiched on both sides by the gasket. If your window fails to stay in its upmost position, this will allow wind noise if not sandwiched between the gasket. You can see a production chart below up to the 2017 model year to get an idea of how few examples you have to gather door gasket life cycle information from…and remember the f06 debuted in the 2013 model year:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 05-12-2024 at 08:23 AM.. |
Nickers0016.00 |
05-12-2024, 09:45 AM | #9 |
Rep 23
Thanks bud, yeah at times it feels really loud then at other timesits fine.
might just be a mix of Akra exhaust and different road surfaces here
BMW M6 GC 2015, Singapore Grey
Tags |
crack windows, extreme heat, side window vent visor deflector, side windows |
