02-06-2024, 08:21 AM | #2 |
Rep 2,926
Are your wheels the same width, or did somebody put the same size tires on staggered wheels?
marlboroplug3.00 |
02-06-2024, 08:28 AM | #3 |
Rep 35
I have a feeling wheels are staggered, car is RWD and the rims should be OEM. Will have to check later since the car is not with me at the moment. Panel on the driver side column said 275 at the back.
02-06-2024, 09:11 AM | #4 |
Rep 7,588
Have you decoded your VIN? If yes, what is your wheel style (or wheel style number)? Without knowing what wheel is being discussed...the forum is in the dark. We don't know if you have a square or staggered setup. Help us help you better...give us enough info to work with.
marlboroplug3.00 |
02-06-2024, 09:39 AM | #5 | |
Rep 35
02-06-2024, 04:19 PM | #6 | |
Rep 7,588
That is a staggered set of 20" Style 373 wheels that came from the factory with
So either the previous owner or the vendor changed the rear tires (or did they change the wheels, too?). style 373 wheels & 20" summer tire run-flat recommendations: (see wheel specs below)
marlboroplug3.00 |
02-07-2024, 03:07 AM | #8 |
Rep 35
02-07-2024, 03:09 AM | #9 | |
Rep 35
02-07-2024, 05:00 AM | #10 |
Rep 7,588
If you dismount the wheels…you can also just check the BMW part numbers & specs which will be located on the backside of the wheel’s spokes. That is another way to verify which size you have.
You can see what the part nbrs & specs are in the pics posted above from the part database for the wheels. And you can also see an example of the rear wheel’s part nbrs and wheel spec info that you should find on the back side of the spokes in the pics below (looks like the last 7 digits of the BMW part nbr is used instead of the complete 11 digit part nbrs. This is normal…sometimes its the complete 11 digits, but sometimes only the last 7 digits are given:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 02-07-2024 at 05:16 AM.. |
02-07-2024, 06:14 AM | #11 | |
Rep 35
