01-18-2024, 01:28 PM | #1 |
Rep 9
305 Rears and 275 Fronts with 10mm Spacers and H&R Springs?
Need to get some new tires, caught a nail in a front tire and the rears are shot anyways. Wanted to go PS4S 305 in the rear and 275 in the front but I'm running the 10mm IND spacers and H&R springs. Anyone have any experience here? Do I have enough room without anything rubbing? Thanks!
01-22-2024, 09:18 AM | #2 | |
Rep 185
Drives: 2013 BMW ///M6 F13
I could be wrong, but I would go with the wider tires and remove the spacers. I would bet they would rub though. |
01-22-2024, 11:17 AM | #3 |
Rep 2,352
The stock wheels are 31mm offset front and 19mm rear.
I'm running 25mm front and 18mm rear with 285/35r20 and 325/30r20 tires, so my setup is: Front: 6mm further out from the offset, then 5mm further out from the 10mm wider tyre - so I'm 1mm further out than you Rear: 1mm further out from the offset, then 10mm further out from the 20mm wider tyre - so I'm 1mm further out than you as well. As such I think you'll be fine and I think that my offsets sit really well on the car - mine is at stock height though.
01-22-2024, 12:58 PM | #4 |
Rep 9
Mine's totally stock setup other then 275 up front with 305s on the back; fitment is perfect, I think.
The front tires rub a little on the wheel liner during 90-degree turns at parking lot speeds, but it's no big deal. I love the look. Rolling on giant marshmallows! |
01-25-2024, 02:59 PM | #5 |
Rep 187
On the rear I run 315 with 10mm spacers no rubbing.
When I had 275 up front I didnt love the look with or with out the spacer. Happy with the look of the 265s and 12mm spacer. |
03-04-2024, 08:03 PM | #6 |
Rep 138
I have 10mm spacer in the front and 12mm spacer in the back.. and I just put the new tires on 275 front 305 back and it's rubbing in the rear.. have not noticed the front yet and its mostly happening when Im turning I think
only rub when I make a big turn normally at the parking lot Last edited by Infiniteflow; 03-04-2024 at 08:54 PM.. |
