08-20-2022, 11:26 AM | #1 |
Rep 10
M6 2016 Blown Engine, Rebuilt and issues after issues with air pressure!
Hi everyone sorry in advance for my horrible bad experience my M6 Cabrio 2016 30k miles seized up a few months back!
I tried to get used warranty and sent it to bmw and they refused it due to computer picked up a Remap a while back apparently so they said! After alot of running around, managed to source a garage that wpuld help me rebuilt my engine and we would fit same engine but with Forged Rods instead of standard Rods! So here is my journey fitting engine :-) Bought a new crank from BMW and to facilitate for the Forged Rods, had the crank precision adjusted weight! Started putting everything back together, new crank, rods, and all small bits that go with it, inc new gaskets of course, Did not change the pistons, kept the original ones! Slowly mechanic guy including myself we started putting engine together, double checking every bolt,screw,clip and we did double check and to our knowledge everything is as it should! We fitted all 8 new injectors including all new spark plugs and coil packs! So the moment of truth comes, we start the car and it runs a bit rough on cold start, Bear in mind car is now stock with no remap and cold start active BUT we do have OEM Downpipes Gutted! Once car is warmed it seems to be running nice when driving, when on idle it does run a bit rough and car sort of shakes a bit! So went ahead put back remap, catd deleted, cold start deactivated… still rough cold start and rough idle running even when warm! Plugged computer and only get one error code: 102002: Air Mass, Plausibility: Air Mass To Low Did smoke test— no leaks Swapped MAF’s other way around — no change Swapped MAF’s completely — no change Tuner says you have air leak… Mechanic smoke checked and we put engine together and no smoke leak! Its been so frustrating and time consuming, and realy cant seem to get a break! Really hoping someone had same/ similar experiences and can share more info! Once again apologies for the long essay :-) |
08-20-2022, 12:46 PM | #2 |
Rep 242
I had the same issue, I popped my intake manifold.
https://www.6post.com/forums/showthr...1914829&page=2 |
08-20-2022, 01:15 PM | #3 | |
Rep 10
One thing for sure this roughness is only apparent when cold start (worse) and on idling… once the car is above 2000 rpm it runs bloody smooth! |
08-21-2022, 12:55 PM | #6 |
Rep 10
Well car went inn and all dealer told me was that there was ecu modifications at some point but were not present.. the dealer told me if we sent to warranty they will refuse it instantly!
I was also told since June 2020 bmw has implemented a system called Pop Up which automatically scans your car and send live data to BMW… |
08-27-2022, 12:18 PM | #7 |
Rep 185
Drives: 2013 BMW ///M6 F13
[QUOTE=LeonBisha;29243508]Hi everyone sorry in advance for my horrible bad experience my M6 Cabrio 2016 30k miles seized up a few months back!
I tried to get used warranty and sent it to bmw and they refused it due to computer picked up a Remap a while back apparently so they said! After alot of running around, managed to source a garage that wpuld help me rebuilt my engine and we would fit same engine but with Forged Rods instead of standard Rods! So here is my journey fitting engine :-) Bought a new crank from BMW and to facilitate for the Forged Rods, had the crank precision adjusted weight! Started putting everything back together, new crank, rods, and all small bits that go with it, inc new gaskets of course, Did not change the pistons, kept the original ones! Slowly mechanic guy including myself we started putting engine together, double checking every bolt,screw,clip and we did double check and to our knowledge everything is as it should! We fitted all 8 new injectors including all new spark plugs and coil packs! So the moment of truth comes, we start the car and it runs a bit rough on cold start, Bear in mind car is now stock with no remap and cold start active BUT we do have OEM Downpipes Gutted! Once car is warmed it seems to be running nice when driving, when on idle it does run a bit rough and car sort of shakes a bit! So went ahead put back remap, catd deleted, cold start deactivated… still rough cold start and rough idle running even when warm! Plugged computer and only get one error code: 102002: Air Mass, Plausibility: Air Mass To Low Did smoke test— no leaks Swapped MAF’s other way around — no change Swapped MAF’s completely — no change Tuner says you have air leak… Mechanic smoke checked and we put engine together and no smoke leak! Its been so frustrating and time consuming, and realy cant seem to get a break! Really hoping someone had same/ similar experiences and can share more info! Once again apologies for the long essay :-)[/QUOTE Holy exclamation points batman |
08-28-2022, 02:11 AM | #8 |
Rep 104
So this issue wasn't on my M6.. but on my GTR kept getting "air mass to low" CELs and I couldn't find a leak anywhere. (This was after beating on the car all summer).
Tuner suggested new fuel pumps and that actually fixed my issue (they were already aftermarket). Not sure if there's a way to 'test' the HPFP's but worth asking someone who would know. |
09-09-2022, 06:22 AM | #9 |
Rep 10
So
An update, did smoke test and no leaks anywhere… update the car to latest softjust in case and no difference…. Opened engine again and fitted two new valvtronic valves and still no change…. The annoying thing is when I disconnect the crank shaft sensor the car runs smooth but it goes into emergency mode! When everything connected the roughness on idle comes back on, and smell of fuel is quiet noticeably… Still trying to find the issue :-( |
12-30-2022, 02:09 AM | #11 |
Rep 244
Drives: M3 E92 & M6 GC
I had an issue similar to this. Swapped my HPFP and voila!
It was covered under warranty for 10 years or 100k, or 120k (don’t recall exactly), apparently S63s have a known issue with HPFPs |
03-17-2023, 03:52 AM | #12 |
Rep 310
Humm sometimes the issue can be as simple and paying close attention to the MAF connector and clip… these two connectors get brittle and temperamental after many years of engine heat and when unplugged and replugged…
It happened to me and led me down an expensive list of parts that at the end were not needed… the issue for me was ensuring these plugs were seated perfectly and secured then locked with their little clip… On a side note - engine rebuilds and breakin procedure is very strict… |
Tags |
bmw m6 |
