05-16-2022, 01:26 PM | #1 |
Rep 1
Will staggered wheels fit 640xi?
I am looking at purchasing Enza-Vatore wheels (5x120 bolt pattern) for a 2014 640xi
20x9.0 ET 35 offset with 255/35/20 tires, R 20x10.5 ET 42 offset with 295/30/20 tires These are off a RWD 550i and I am unsure if having an AWD model will cause any issues. |
05-18-2022, 04:59 PM | #2 |
Rep 7,584
Just go to one of the online part database sites like www.realoem.com or www.bimmercat.com and pull up the 20" staggered wheel diagrams for your car (based on its VIN or build date etc). Compare the 20" staggered BMW wheel's specs to the aftermarket wheel's specs to see if they are close/similar...or if you'd need to use adapters and/or spacers to make them fit.
Also check the 20" staggered tire sizes to make sure you stay close to original specs.
05-20-2022, 04:29 AM | #3 |
Rep 2,026
check rolling radius charts,,could play havoc with x drive,ive went from 255-35 ..225-40 to now square 245-40 on my f31 330d x drive,,lower the % of rolling radius is better for x drive.
07-01-2022, 06:36 PM | #4 |
Customize Everything!
44
Rep 279
+1....Must keep it under 1% difference from stock rolling diameter so you don't damage your transfer case. The car will start to think your losing traction or hydroplaning and transfer power to the other wheels.
Tags |
640xi rims, fitment, wheels |
