      11-21-2019, 02:50 PM   #1
finalfan7asy
finalfan7asy's Avatar
Drives: BMW M6 Grand Coupe
Leather Dye?
Has anyone dyed their leather? I have a couple small flawed areas in my door panel leather and would like to repair it.
      11-21-2019, 03:30 PM   #2
NorthCountryGuy
The Quiet One
NorthCountryGuy's Avatar
1713
Drives: M6, E70, E71
2013 X6 M  [0.00]
2013 M6  [0.00]
2013 X5 LCI 35i Spo ...  [0.00]
2013 X5 LCI 35i  [0.00]
Look here.
https://www.colourlock.com/bmw_leath...a?___store=usa
2013 X5 LCI 35i Jet Black / Black SensaTec - The Horse
2013 X5 LCI 35i Space Grey Metallic / Black Nevada // Sport Pkg - Daughter’s
2013 X6 M Sapphire Black Metallic / Black Merino \ Carbon Fiber - Son’s
      11-21-2019, 03:52 PM   #3
sixfiftyay
Drives: 2013 Bmw 650I Gran Coupe
i've used doc bailey's and had great results. very easy to use as well.
      11-21-2019, 06:10 PM   #4
doggboy
Drives: BMW 650i
When i was looking to touch up my benz, these were the guys that were recommended most often.
http://www.leatherique.com/oem-color-samples/bmw.html
      11-21-2019, 11:00 PM   #5
finalfan7asy
Thanks for the info!
      11-22-2019, 11:26 AM   #6
MMMM6GC
Drives: M6 GC
Interested to follow your progress and results. I really like the colourlock solution, will have to search more people's results. Also came across this post by a fellow member who used a Swissvax kit with some decent looking results.
Going to go one of these routes I think...
      11-22-2019, 01:46 PM   #7
jjasonSU
Drives: 650i, NSX
I needed the same when i bought my F13 last year. (before pic)
I ordered a kit from leatherworldtech and it worked great. I had vermillion red so it was harder to match.
But black should be easier.
The kit came with sponges and filler putty.
      11-22-2019, 08:19 PM   #8
MMMM6GC
Drives: M6 GC
any after pics??
      11-25-2019, 11:23 AM   #9
finalfan7asy
I reached out to Colourlock and they informed me to buy their kit which includes a sand block. I’m nervous to sand the blemished areas. Has anyone sanded leather prior to dying it?
      11-25-2019, 11:51 AM   #10
NorthCountryGuy
The Quiet One
1713
2013 X6 M  [0.00]
2013 M6  [0.00]
Yes.
I did a complete seat restoration on a 32 yo Porsche.
I didn’t use a block. I just used a 1200 grit emory cloth/paper. Is important to do, but gingerly. Once you start you’ll get the feel. Then you gently wipe off with a clean non filamentous cloth impregnated with a solvent. No hairs/fibers to be left. Let it dry. Apply a hair drier to warm up the leather before pigmenting it.
Add: important to do all steps on a non obvious area to make sure you’ll be good. Bottom of seat face behind the heels of your foot would be good.
      11-25-2019, 12:37 PM   #11
Opie55
Drives: '15 650i Convertible
I've dyed leather several times. For something that small I would not do hardly any prep. That is way different than doing a seat restoration on an old car. If you start sanding or using a solvent you will just end up with a bigger area to fix. You can always redo it with more aggressive methods, but don't start there. 99.9999% of your issue is color match, and second is sheen match. As you can see from your own photo comparing the speaker cover and door pull, that "black" is not even close to true black. Once you have a true color match, clean that area well with leather cleaner and then just use water and a dry rag. Let it dry a while. Then take your dye on a cotton rag stretched over your fingertip and and pit just a tiny amount on it and just dab it there like you would alcohol on a cut if you hate pain. Try to only dye the worn area.
      11-25-2019, 04:15 PM   #12
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
If you want a little more precision, I use these touch up paint applicators to apply dye. I would never used these for touch up paint.
https://www.amazon.com/dp/B07SQ8TGP4..._t3_B00578QW70
      11-25-2019, 09:19 PM   #13
finalfan7asy
Maybe just adding color to the area instead of sanding it might be best. As long as it blends, I would be happy with the results.
      05-26-2023, 09:35 AM   #14
Montana89
Drives: Honda Civic
Hello, I also would like to refresh the color of my leather seat. Could you provide recommendations for specific dyes or coloring products that you have used? I recently came across an online a restoration product, but I am still uncertain and would like to make an informed decision to ensure I choose the right option and avoid wasting money. Thank you in advance.
      05-26-2023, 05:26 PM   #15
Alpine650
I use Johnston & Murphy Shoe Cream on my black leather seats where they wear on the bolsters. A great match!
      05-27-2023, 08:40 AM   #16
Opie55
I depends on what you are trying to do. What do you mean by "refresh"? You are almost always better off limiting dye to damaged areas if possible. Maybe post a pic or two? I just recently got a product from England and I remain rather stunned by how well it worked and how closely it matches. Here's the link:
https://thescratchdoctor.co.uk/produ...pair-products/
      05-27-2023, 08:21 PM   #17
Alpine650
Here is the Before/After with shoe cream:
