      06-07-2018, 05:26 PM   #1
pr0xy
Drives: 2012 BMW M6 Convertible (F12)
2012 BMW M6 w/ 4800 miles - odd noise
Hello forum members,
I have a 2012 BMW M6 (F12), with Mission Performance stage 1 tune.
In the past 200 miles, I have an experienced a high pitched squeaking/squealing noise, especially in the beginning of the engine warmup phase. After the car warms up, the noise stops. When I open the front hood, I can barely hear it, but I can hear it more underneath the vehicle. The sound increases in tempo when the throttle is pressed. It isn't impacting the vehicles performance... at least none that I noticed.
I am posting 3 videos, to see if I could get some feedback.
https://photos.app.goo.gl/tV80EJmJhOVz7GB53
Thank you kindly,
Sebastian
      06-07-2018, 07:07 PM   #2
Flying Ace
Flying Ace's Avatar
4985
it's going to be a pulley or a belt related to the motor and attached accessories. I want to say, it'll be a idler pulley belt. But every belt needs to be checked.
      06-07-2018, 08:05 PM   #3
pr0xy
Thanks for the reply.
I wonder if I added a little bit too much oil, if that would cause this particular issue. I'm trying to drain half a quart to see if the issue subsides.
      06-07-2018, 09:37 PM   #4
hirkaismyname
Drives: F06 CP GC
It may also be a mid pipe (or rear axle back junction) gasket replacement?
I had this issue before, and it would get loud upon revving. Noticing the third video, it seems like it did get louder.
And, it kind of resembles the sound a steam engine -- but a really small one that compressing air?
Either way, have them check the seals for the exhaust system. If you're the 2nd owner, then the previous one might have given the vehicle an exhaust upgrade temporarily before selling the vehicle to you (or back into BMW at lease end).
Cheers.
      06-08-2018, 06:10 AM   #5
pr0xy
Thanks for the feedback. I do have an aftermarket exhaust.
The sound subsides and totally stops once the engine is warm. Could that still be an exhaust gasket issue? I'm trying to take her to the mechanic... I hope it's nothing catastrophic or $$$ - but I will definitely update this thread once I get an answer or fix. Wish me luck.
      06-09-2018, 01:22 AM   #6
Flying Ace
Flying Ace's Avatar
4985
It won't be catastrophic...
      06-26-2018, 03:59 PM   #7
pr0xy
Just an update on this issue... I have taken the vehicle to 2 shops. One a BMW Dealer in Columbia, SC and an independent BMW shop in Augusta, GA. The BMW shop doesn't see anything wrong and the independent shop believes it is a connection issue between the midpipe and downpipe. They tightened the exhaust connections and the sound went away but came back this morning. Does anyone else have any recommendations or any other shops I can take it to? Thank you in advance.
      06-26-2018, 04:13 PM   #8
BMWDriverX
Drives: G12 750i X-Drive
Get new gaskets/rings for the exhaust where it connects to the downpipe. Should solve your issue.
http://www.6post.com/forums/showpost...0&postcount=10
18307844741
18307843213
      06-26-2018, 04:55 PM   #9
pr0xy
Spot on... I just got off the phone with Alex from Mission Performance (they did my tune) and he relayed the same thing - recommendation to change the gasket. I am doing a catless dp install this Friday, so I will ensure to change everything out. I will update the forum once I complete the install on Friday.
      06-26-2018, 06:30 PM   #10
BMWDriverX
Alex is the man! I work with him as well, his work in tuning is flawless!
      06-26-2018, 10:33 PM   #11
BM dnobagaV
BM dnobagaV's Avatar
Drives: 2010 BMW 528i
Nah it's the rod bearings.
Time to change out the engine.
Heil BMW!
      06-29-2018, 03:32 PM   #12
pr0xy
Heil BMW!
Rod bearings after only 5500 miles on the engine? You jest.
      06-29-2018, 08:51 PM   #13
pr0xy
Update: Today I replaced the gaskets that connected the midpipes to the downpipes. It totally eliminated the sound... thanks for all the feedback.
K737.50
      02-27-2019, 07:31 PM   #14
Sam21LBC
Drives: BMW 640i
I'm having a squealing noise come out in my 640i not sure if yours sounded the same.
https://drive.google.com/file/d/1M-g...w?usp=drivesdk
      02-28-2019, 02:15 PM   #15
BMWDriverX
That's not the sound from the gasket. That sounds like a busted pulley bearing. Take it in to a shop and have them replace the faulty pulley before it locks up on you and shreds your belt among other issues it can cause depending on which pulley it is.
      02-28-2019, 06:16 PM   #16
Vigorspeed
Drives: 2010 BMW M6 V10
Heil BMW!
Schwanz
      03-14-2019, 08:28 PM   #17
pr0xy
Yeah, that's not the same noise... Definitely sounds like a pulley.
      03-16-2019, 05:37 AM   #18
Roccaas
Mid life crisis
Drives: 2012 650i Convertible F12
Take a bar of Ivory soap, let the car idle, hold the soap along the underside of the belt, repeat weekly or whenever it rains.
Next week on Redneck fixes: packing your tires with corn shucks, cheaper than a new inner tube. Check our video feed for last week's episode, beer can steel, better than lead babbitt?
/sorry, thought I was on my Model A site.
langnasiger silberner Bayerischer Hai
