      02-19-2014, 02:32 PM   #1
LSM
LSM's Avatar
Drives: 2024 Porsche 911 GTS Cab
Dyno'ed M6 on dynojet
My car has charcoal filters removed Nothing else
2024 Porsche 911 GTS Cabriolet
      02-19-2014, 02:44 PM   #2
TunedM2C
TunedM2C's Avatar
Drives: 2016 LBB M2
Well, looks like your fill ups from now on are going to be a bit more expensive. Lol
      02-19-2014, 05:47 PM   #3
gmd2003
gmd2003's Avatar
352
Drives: 2014 CP M6 and 2006 VT 525 Z4M
Originally Posted by LSM
Yea exactly....there's no baseline though on this dyno, so who knows...just thought would post results from dynojet...
Different dyno ( different type of dyno too) , different calibration , different conditions etc . Dynojets read high , certainly much higher than Mustang dyno's too , so without a baseline this doesn't mean anything to be honest . But given how the BMS works by increasing boost beyond whats tuned and fueled for , 100 octane will keep the ECU from pulling as much timing and you will make more power .
      02-19-2014, 07:08 PM   #4
mr-karim
mr-karim's Avatar
Drives: F13 M6 (Fully Modded)
Not bad at all!
If you have access to 100 octane, then change the PSI level to +3, and 630WHP should be doable.
"The best things in life are free. The second best are very expensive." - Coco Chanel.
      02-19-2014, 07:40 PM   #5
Twitch Massacre
Twitch Massacre's Avatar
Drives: 2015 BMW i8
I12 BMW i8  [0.00]
F13 BMW M6  [0.00]
This looks a bit better.
H&R Springs
21" ADV.1 ADVNL2 MV2 CS Wheels
Coming Soon:
2016 BMW M4 GTS De-Winged and Bagged on 22s
      02-19-2014, 08:50 PM   #6
turbo8765
Drives: very fast
It would be interesting to do before and after race gas dyno's on a stock M6.
      02-20-2014, 11:00 AM   #7
bjayfan
Drives: 2014 F13 M6
A dynojet in an inertia dyno, anyone should expect to see higher numbers compared to the mustang.
      02-20-2014, 12:16 PM   #8
Hunter5179
Hunter5179's Avatar
Drives: 2013 M6 Coupe
Nice
My Thread:
      02-20-2014, 12:40 PM   #9
bjayfan
Drives: 2014 F13 M6
Originally Posted by LSM View Post
I am just posting my results from the dynojet which I am very happy with.
Which gear did they use?
      02-20-2014, 03:27 PM   #10
bjayfan
Drives: 2014 F13 M6
4th, the first two runs we tried there was major wheel slipping. The last run which I posted was the only semi clean run
So it's off, should use as close to 1:1 as possible, and that's 5th on the M6.
      02-20-2014, 03:31 PM   #11
bjayfan
Drives: 2014 F13 M6
Yea I know it's supposed to be 1:1 u do know 5th gear run cant be made because I hit the 155 max speed limiter before 5th gets to redline
Yep, which is why using a Dynojet with an M6 makes zero sense.
      02-20-2014, 03:36 PM   #12
bjayfan
Drives: 2014 F13 M6
Any dyno I run on in 5th will hit max speed limiter before redline
Perhaps, I haven't tried them all. But with a retarder type of dyno (like the Mustang) what data you do get will be a great deal more reliable.
      02-20-2014, 03:40 PM   #13
bjayfan
Drives: 2014 F13 M6
Mustang I ran previously also in 4th gear ... I am going to go back on mustang in a few weeks it's 60 miles from me
It's about 85 miles for me, so I do understand.
      02-28-2014, 12:52 AM   #14
badblack550xi
badblack550xi's Avatar
Drives: F10 550i 2011 F90 2020 COMP
Originally Posted by mr-karim View Post
Not bad at all!
correction he can run +4 PSI on 100 octane only.
2011 550i RWD 60-130 7.35
      02-28-2014, 05:03 PM   #15
JoeyLeeBMW
JoeyLeeBMW's Avatar
Drives: 2014 BMW ///M6 Alpine White
I think you may have a factory freak!
Joey Lee BMW l ///M Power l IG: JoeyLeeBMW
2014 BMW ///M6 Coupe "Competition Package" CLICK: Intro Thread Pictures
l Vorsteiner CA Demo Car l Toyo Tires l Trinity Autosport l Targa Trophy l Shift S3ctor
      03-01-2014, 06:33 AM   #16
turbo8765
Drives: very fast
You've posted SAE correction. Do you by chance have the uncorrected graph/number?
      03-01-2014, 09:13 PM   #17
turbo8765
Drives: very fast
Copied directly from the dynojet manual… the pdf is available for download via google search.
"Data can either be viewed as measured (“uncorrected”) or corrected to standard atmospheric conditions using WinPEP."
Measured values for hp/trq are greater than corrected values when the DA as measured by the dyno's instruments is less than DA at standard conditions.
Why do I care? The 63tu increases boost to compensate for increased DA to maintain output under less than ideal conditions, therefore raw values should be presented in most cases. Otherwise you may be applying a correction factor when the ECU has already compensated for increased DA.
      03-01-2014, 09:34 PM   #18
LSM
LSM's Avatar
I understand but what I am saying is I saw the uncorrected values they were higher. The dyno operator showed me uncorrected was close to 600wheel hp. He said we use sAE as standard on dynojet The one I posted the sAe corrected is lower than the Uncorrected numbers
      03-03-2014, 01:36 AM   #19
SlashM3
Drives: 09 E93 M3 interlagos
Do u feel the difference with the piggy back?
      03-04-2014, 09:15 PM   #20
gmd2003
gmd2003's Avatar
352
With mixed race gas and our premium 91 octane yea I feel a bit of difference nothing major
The problem is I'm sure I would get a significant bump from running race gas with my stock CP tune lol .
      03-04-2014, 10:19 PM   #21
zoltans4
Drives: '14 650 coupe
yes, you would (depending on your definition of significant)
      03-05-2014, 06:51 AM   #22
gmd2003
gmd2003's Avatar
352
We have 91 octane in Cali I mixed 1/4 tank of 100 octane and 3/4 91....SO the octane was what 93.25.....what everyone else in the country runs
Well not really , most race fuels have anti knock additive packages in them irrespective of their octane . Shell URT adv is an excellent example . It is only rated at 110 octane yet greatly outperforms even 114 octane fuels because of its additive packages . Once you start adding " 1/4 tanks" of race fuel you can't say you have the equivalent of 93 pump .
