      05-06-2014, 02:30 PM   #1
mr-karim
mr-karim's Avatar
Drives: F13 M6 (Fully Modded)
Post BMS +2.5 PSI Dyno result
Still don't like the torque line.
Here is Dyno +2.5 PSI over stock
And +3 PSI over stock
"The best things in life are free. The second best are very expensive." - Coco Chanel.
      05-06-2014, 02:49 PM   #2
mr-karim
mr-karim's Avatar
And a video of course
      05-06-2014, 06:46 PM   #3
LSM
LSM's Avatar
Drives: 2024 Porsche 911 GTS Cab
Mr Karim,
What fuel were you running? Straight 93 or a mix? Thanks
2024 Porsche 911 GTS Cabriolet
      05-06-2014, 06:47 PM   #4
LSM
LSM's Avatar
I thought you wrapped your car brilliant white??
      05-06-2014, 07:00 PM   #5
mr-karim
mr-karim's Avatar
Originally Posted by LSM View Post
Mr Karim,
94 octane + NOS octane booster. Unwrapped the car a few weeks ago.
      05-06-2014, 07:47 PM   #6
LSM
LSM's Avatar
Those are interesting results you know at 2.25 and average about 94 octane I hit 590rwhp and 545W Lb/FT and I dont have any mods at all..I wonder if that exhuast is robbing your torque??
I need to retest with new settings
      05-07-2014, 02:47 PM   #7
JoeyLeeBMW
JoeyLeeBMW's Avatar
Drives: 2014 BMW ///M6 Alpine White
Great numbers!
Thanks for sharing Mr.Karim!
LSM - We need to do a side by side comparison & dyno run at EAS!
Joey Lee BMW l ///M Power l IG: JoeyLeeBMW
2014 BMW ///M6 Coupe "Competition Package" CLICK: Intro Thread Pictures
l Vorsteiner CA Demo Car l Toyo Tires l Trinity Autosport l Targa Trophy l Shift S3ctor
      05-07-2014, 04:39 PM   #8
gmd2003
gmd2003's Avatar
352
Drives: 2014 CP M6 and 2006 VT 525 Z4M
Mr Karim,
Interesting , you are still running too lean on several of those runs and that's why you're torque is low . An AFR of 16 plus, is really unsafe at redline if those are accurate. Do you have any stored error codes in the ECU ? I'd get you're car checked out , and until then go back to the standard 2.25 setting on the old firmware .
      05-07-2014, 05:49 PM   #9
mr-karim
mr-karim's Avatar
Standard is 2.5 for s63tu engine with 93 octane +
      05-08-2014, 02:05 AM   #10
gmd2003
gmd2003's Avatar
352
No the default is 2.25 for pump gas on the old firmware . But that doesn't change the fact that you're AFR's are off really bad , again if they are accurate . I would scan you're car for error codes and make sure everything else is functioning well , bc as you said you're power curves are off pretty bad in several of the runs .
      05-08-2014, 11:54 AM   #11
LSM
LSM's Avatar
Originally Posted by JoeyLeeBMW View Post
Great numbers!
Joey,
Sounds good, when you avail?
      05-12-2014, 02:41 PM   #12
michel lane
Drives: BMW M6 F13
Hi, coming from a tuning background, you are running really lean there , turbo charged cars should be running between 11-13 on the AFR on full boost, depending on the timing. If you ever hit 14-16 on a Jap car , it would have gone pop by now, just shows you how well engineered these engines and ECU are. This ECU must be running knock detection and pulling power back tremendously. I would suspect its your de-cats that has caused this, as the exhaust is flowing without any restrictions.
Have you dyno'd the car with the cats on before ? so you can compare the AFR, your car looks great . Get it seen to before you do anymore crazy runs .
      05-12-2014, 05:44 PM   #13
mr-karim
mr-karim's Avatar
Hm, do you think the problem is in downpipes?
      05-12-2014, 06:34 PM   #14
michel lane
Drives: BMW M6 F13
From the tuning world that I have come from, reducing the restriction in an exhaust system and allowing the engine to breath better always requires additional tuning to compensate for this .
I am not sure about how the BMW M6 ecu handles this, it may have parameters to compensate within a certain range , but looking at you dyno graph it seems that the ecu is not running O2 feedback . This is were it self tunes itself if the values of the AFR exceeds a certain range. This is a great idea but relies on one aspect , the lambda sensor is accurate. A lot of GM motor cars have this feature as they have 2 banks of sensors.
Then again , seeing the AFR reaching such a high value and the ecu reducing the power , says one thing about these cars , the ecu is pretty good . I bet it is also reducing boost . It's a shame you haven't got boost reading on the dyno graph aswell.
On the other hand , it could be a faulty wideband sensor on the dyno , giving you wrong readings . Get it dyno'd again and but put the piggy back to stock setting then slowly increase the boost on each of the run . Make sure they log the boost , AFR, torque ,hp on the same graph . But in the mean time , knock the boost to stock to be safe .
I am hoping to stick mine on the dyno this weekend to see what the AFR is like on boost, don't get to involved in chasing numbers on a dyno, tuning is all about power delivery and drive ability, pointless having all the power up top when there is nothing mid range .
Tags
bms, dyno, f13 m6
