      08-30-2023, 08:04 PM   #1
BMWisBest
BMWisBest's Avatar
117
Drives: 2014 BMW M6
Best Offset for Flush Fitment???
What's up gang.
Im ordering custom wheels and need to know what the offsets needed are for a 20 x 10 front and 20 x 11.5 rear.
Going to run 275/35/20 tires in front and 305 or 315/30/20 in rear.
Help a brother out 🙏🏻🙏🏻🙏🏻
      08-31-2023, 01:32 PM   #2
brad850csi
Drives: 16 F13 M6 Comp
Here is my setup, similar to what you are looking for
https://www.6post.com/forums/showthread.php?t=1677487
BMWisBest117.00
      08-31-2023, 02:22 PM   #3
BMWisBest
BMWisBest's Avatar
117
Drives: 2014 BMW M6
My man! Appreciate it bro. And to confirm is this an m6 or standard 6 series? Are the specs the same?
Also is this flush with the fenders? Do you have any pictures that show how they line up?
      08-31-2023, 02:56 PM   #4
BMWisBest
BMWisBest's Avatar
117
Drives: 2014 BMW M6
Also, do you know how much room do you have between the wheel and your upper wishbone & strut?
I want to camber the fronts top -2.5 and trying to confirm if I would have room if possible!
      09-02-2023, 03:18 PM   #5
Originally Posted by BMWisBest View Post
What's up gang.
Help a brother out ������������
It all depends on what offset and specs your replacement wheels/tires will have.
I would suggest running a comparison of your existing wheel tire set up to your new wheel tire set up at this site: www.willtheyfit.com
You will have to measure your existing distance from the fender and suspension to compare what (if any) difference you’ll get from the new setup. (How much poke toward the fender or inset toward the suspension)
This can also help if the new specs do not push the wheels out flush with the fender…you’ll now what size spacers you’ll need…or different wheel/tire selection to make to get the flush you’lre looking for.
      09-03-2023, 02:36 PM   #6
brad850csi
Here's another one for you, the offsets are really good - I'm at stock ride height so if you lower it the top will tuck in a little bit
      09-05-2023, 09:44 AM   #7
richlandforged
richlandforged's Avatar
433
Drives: F13 M6, E70 X5d, e46 330ci zhp
BMWisBest
We recommend for ideal tuner fitment the specs as designed on our M6 version our new GT3R wheelset:
https://www.richlandforged.com/product/M5M6GT3R/35
20x10" ET+25
20x11.5" ET+16
Recommended tires: 275/35/20, 315/30/20
BMWisBest117.00
      09-05-2023, 09:56 AM   #8
BMWisBest
BMWisBest's Avatar
117
Drives: 2014 BMW M6
Originally Posted by richlandforged View Post
BMWisBest
20x10" ET+25
20x11.5" ET+16
Thanks so much! How much room does this leave in the front between the wheel and the wishbone/strut?
Will there be room in the front to increase camber to let's say -2.5?
      09-05-2023, 07:37 PM   #9
richlandforged
433
Even at -2.5, approximately 10mm of headroom should be available, of course dependent on exact sidewall profile/make,model of tire.
      09-24-2023, 06:52 AM   #10
NiksM6
Drives: ‘15 M6
20x10 et23
20x12 et23
265/35
335/30
On oem competition springs, perfectly flushed!
      09-24-2023, 08:55 AM   #11
danielgmanm6
danielgmanm6's Avatar
Drives: 2013 BMW ///M6 F13
2013 Bmw M6  [0.00]
  [0.00]
  [0.00]
Do you have a problem with rock chips? I was always afraid of rock chips destroying my paint from the wheels being so flush.
      09-25-2023, 02:07 PM   #12
brad850csi
The Cup 2s absolutely ruined the rocker panels (or side skirts depending on your region) and rear bumper after a few hot days on new loose chip roads.
But the PS4Ss aren't as bad and driving a bit slower on loose chip roads has kept the rear bumper looking good after a respray. I now have PPF on the rocker panels
