      05-08-2024, 04:11 AM   #1
marlboroplug
Drives: 2015 BMW 640i F06
How would i go about this?
No check engine light and the code is not under the permanent code menu.
      05-08-2024, 08:40 AM   #2
Opie55
Drives: '15 650i Convertible
Look it up on bmwfault.codes It tells you what the common causes are. But step one is to clear it and see if it comes back. But the site says to check the wire connection to the servo motor, or that it may need a new motor and shaft.
      05-08-2024, 09:00 AM   #3
marlboroplug
Tried to clear the code immediately after i saw it but the code is persistent, maybe i should do some miles before i try again. The car is fine overall no drop in performance so i am not sure if the problem is significant but will have to see how it turns out.
