04-25-2022, 12:15 PM | #23 |
Fueled by Recycled Dinosaurs!
647
Rep 1,180
Drives: F06 M6
Plus ya didn't have to put out a fire so that is good. Can you get the pcv by itself or do yu have to buy the entire cover?
04-25-2022, 01:01 PM | #24 |
Rep 632
It is not broken out as a separate part number. See illustration below.
F06 M6 Grand Coupe CP
TinCanSailor647.00 |
04-25-2022, 02:41 PM | #25 |
Rep 242
True Yeah the full cover must be replaced, injectors gasket ring & decoupling element and hpfp profile gasket with pipe
Found the part number but it doesn't exist. Update: That is the part number for the kit 11158636541 Last edited by M6Roar; 04-25-2022 at 03:08 PM.. |
04-30-2022, 05:08 AM | #26 |
Rep 242
Found the leak yet not sure intake or valve cover
04-30-2022, 09:32 PM | #28 |
647
Rep 1,180
Drives: F06 M6
Honestly, I'd be giving a call to Raza. These things are his passion and he will point ya in the right direction. Depending on your goals there are a number of items to be considered. He also makes a billet intake that would be a wise choice.
M6Roar85.50 |
07-18-2023, 12:35 AM | #32 |
Rep 242
02-29-2024, 03:22 AM | #33 |
Rep 2
hi,
i had the same issue before I rebuild the engine and I've changed everything ( vacuum lines, pcv,ccv system the hoses over the valve cover and the ones under the valve cover, 4 new Vanos solenoids, 8 brand new injectors, 2 air mass sensors, 2 intercooler sensors, 2 intake manifold sensors, and I checked the 2 intake manifolds for any leaks while the engine was out and there was no leaks at all, but i found out something weird, when I unplug the fuel tank ventilation valve located on bank 2 the engine works with no issue and the code doesn't get back until I plug it again. and I still don't know the issue.. please help.. i have a 650i GC 2013 with n63b4401 engine. |
