      04-07-2019, 03:25 PM   #67
gatorfast
gatorfast's Avatar
Drives: 718 Cayman
Originally Posted by cookiesowns View Post
I’m going to be running Ravenol SSL 0W-40 on my M2C. Actual group IV PAO.
It’s also the only 0W-40 that I could find with LL01 cert.
However Amsoil has a relatively new line of European oils with LL01 cert with really good specs that I may try on the other cars.
My driving cycles are much shorter now so hence why I went with 0W-40 instead of 5W-40
Castrol 0w40 is still readily available and has the LL-01 cert. I believe some newer batches though have dropped the LL-01 cert.
      04-07-2019, 03:40 PM   #68
Shredicus
Shredicus's Avatar
535
Drives: E92 M3
Amsoil 5w50
      04-07-2019, 06:10 PM   #69
hardparker
Father of Frankenfold
297
Drives: Yo daddy's 2014 X3 M Sport
2013 BMW X1  [0.00]
2014 BMW X3  [0.00]
Previously Castrol 0w40 A3/B4 LL01. Now LiquiMoly 0w40 with Ceratec.
      04-07-2019, 06:19 PM   #70
m1256
Drives: 2014 BMW x1 sdrive28l
Total 5w40 9000 quartz in my N20.
      04-08-2019, 01:33 AM   #71
cookiesowns
cookiesowns's Avatar
592
Drives: X5 45e, 535i N54, X3 N55
I refuse to run non PAO / Group IV oil now... which Motul /castrol/penzoil/just about every other oil is out of the question for me, unless im doing alot of track days then it's 300V.
Ravenol is very expensive, so if my UOA and VOA looks good on Amsoil on my other car, I may switch to it on the S55.
BM3, MHD, ECUTek Calibrator | N55/S58 specialist | 2023 X5 45e Frozen Marina Bay Blue
      04-16-2019, 04:57 AM   #72
JTFS
Drives: BMW 428 Xdrive Gran coupe
2015 N20 & 2016 N26 0-30w / 0 20w?
I am curious as to what is the difference between the 2015 428i N20 and the 2016 428i N26. The 2015 428I N20 calls for 0W-30 and my 2016 428i N26 calls for 0W- 20? Why did BMW change the oil weight?
      04-16-2019, 11:38 AM   #73
LeeMT
LeeMT's Avatar
Drives: E92 & E90 M3,F98 X4M
use Fucha 10w60 all the time, anyone else?
      04-16-2019, 11:44 AM   #74
Z K
Z K's Avatar
1910
Drives: G20 M340i, S15 Silvia Spec R
The engine hasn't changed. What has changed is that BMW is looking to get better gas mileage and emissions from the engines. 0w20 allows the car to get up to temp faster and it is better for short trips which is what a lot of drivers are doing.
As for how good 0w20 protects the engine long term, that's up for debate.
I'm planning to use 0w30 LL-01 which is still approved for all years N20/N26.
Auto Detailing Enthusiast!
kyrix1st2426.00
      04-16-2019, 03:32 PM   #75
JTFS
Thanks for reply. I plan on driving from NY to Florida. The 0 - 30w sounds like the better choice over the 20w for the longer trip. I also used the BMW oil.
Z K1910.00
      04-16-2019, 03:46 PM   #76
bgalakazam
bgalakazam's Avatar
Germany
93
Drives: 2015 328i
2015 BMW 328i  [0.00]
Get the BMW oil.. it's not that expensive.
      04-17-2019, 12:23 PM   #77
DanG
DanG's Avatar
Drives: 2018 M2 AW DCT
2018 BMW M2  [7.95]
The BMW oil is Shell oil.
      04-17-2019, 12:26 PM   #78
GoRomeo
GoRomeo's Avatar
Drives: 330i, 135i
2008 BMW 135i  [9.50]
2006 330i  [6.75]
5W-30 I never changed it since new. I am in SD so weather is not an issue.
      04-17-2019, 03:35 PM   #79
CruzM3
CruzM3's Avatar
Drives: 2018 M3 "Velocity Edition"
Depends where you live. Here in Germany the dealers near me use Castrol Edge Professional and both my X3 and 340i get 0W-30.
2018 M3 ZCP "Edition Velocity"
2018 X3 30i (wife’s)
2017 340i w/ MPPSK & Many M Performance Parts (sold)
2016 328i (sold)
      04-17-2019, 04:17 PM   #80
DanG
DanG's Avatar
2018 BMW M2  [7.95]
We use to get Castrol until about two years ago. Then Shell took over. I am sure that it was a sponsorship thing and not that Castrol was inferior.
      04-17-2019, 04:21 PM   #81
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
2014 BMW 328i w/ N26
LiquiMoly SAE 5w40 every five thousand miles.
      04-19-2019, 09:07 AM   #82
sergbaja5t
sergbaja5t's Avatar
63
Drives: 2011 E92-M3 Comp
Rowe 10w60
      04-20-2019, 05:21 PM   #83
JamesGames
JamesGames's Avatar
Drives: E60 550i|F82 M4|F48 X1|VA STi
Castro 0w40 Euro (made in germany) is majority PAO based, as is Castrol 0w30 Euro (Made in belgium). These two out of the entire lineup are the better ones made out of PAO. Motul has a lot PAO formulated oils as well, like the 8100 series. 300V is ester based. What's the issue with these PAO based formulations that you don't want to use them?
      04-21-2019, 08:37 AM   #84
adc100
Drives: 2018 Forester XT
I am kid of an oil freak. I was a maintenance supervisor in a Power plant my whole life (Mechanical Engineer)Done lots of oil analysis both work related and for my cars.
Viewing thousands of oil analysis on BITOG.com. I have pretty come to the conclusion that oil is oil.
My choice now however. QS Ultimate Durability. As far as filters Fram Ultra. This filter has a 99% efficiency at 20 microns. Most filters (if they actually publish their ratings are 99% at 35 to 40 microns.
GM did a test some years back and indicated a 40 micron filter had 3.4 times the wear as a 15 micron filter. Filter is more important than the oil IMHO.
https://www.machinerylubrication.com...ose-oil-filter
      04-21-2019, 08:50 AM   #85
spazzz
spazzz's Avatar
159
Drives: 2008 535xi MHD&XHP,2013 X1 35i
Interesting. I use the Fram Ultras in the other cars, the BMWs get the Mann.
I didn't realize the Ultras came with the o-rings and crush washer until now.
On amazon the fram is over 2x the price as Mann.
      04-21-2019, 09:38 AM   #86
CTinline-six
Hoonigan
CTinline-six's Avatar
Drives: '09 328i, '98 Wrangler
Castrol 0w40
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park
      04-21-2019, 01:35 PM   #87
yco
i'm just saying
yco's Avatar
6019
Drives: E71 X6M '10 (sold)
Castrol 5w-40..
      04-21-2019, 02:17 PM   #88
328iX
David
328iX's Avatar
Drives: 2015 328iX F31
I use 5W-30 Pennzoil Euro-L, one of the few oils I can easily get with BMW LL-04 for my diesel engine, pair it with a Mahle filter
I buy the Mahle filters off rock-auto $11/each
and the oil from Walmart online, it's like $22/5 quart
I also buy two oil changes at a time to get the free shipping off Walmart's website
I do 5k mile OCI, at 5k I do it myself, when I hit 10k on the CBS I take it into the dealership for the free change. They do use 0W-30 but don't think it hurts to switch back and forth.
