06-06-2015, 12:54 PM | #1 |
Rep 536
Spacers or bigger wheels
My car looks under-wheeled, and I am not sure if this is because of the size of the stock 19" wheels, or just a poor offset making them sit inside the fenders.
Would spacers help, or should I go 20"? Should I even bother trying the spacers? |
06-06-2015, 02:57 PM | #2 |
Rep 6,074
You need wider rim/tire with correct offset.
373 rims setup help a lot... they are wider and 20" ; however if you like 343M M5 rims, their setup completely look different. Many people have done this change and seem happy...
06-06-2015, 03:24 PM | #3 |
Rep 536
So you're saying I shouldn't even bother with the spacers?
06-06-2015, 03:31 PM | #4 |
Rep 6,074
Well that's the cheapest way you can go and I don't bother to try it to see if it works... Spacers will change the overall length of track with no inside support, so you may experience less agile characteristic on turns since it's like you are decreasing the offset.
07-14-2015, 06:24 PM | #6 |
Rep 58
Yeah, agree with the others on here. Anything less than the 20" 373M's on this car isn't a great look, imo.
And even those sit way inside the fenders. I would go with the 343's off the M5 or even after-market one's. I've got 373's that I intend to sell but have to find a custom set first. |
07-15-2015, 02:35 AM | #9 |
Rep 63
07-15-2015, 02:39 PM | #10 |
Rep 35
Thanks! I went 245/285 because it was recommended and looks symmetric. 255/295 would be recommended but you want want to confirm with a tire guy. I think the 255/285 might look odd, as the 255 would give a "thicker/taller" look up front
07-15-2015, 03:37 PM | #11 |
Rep 63
I thought the 245 vs 255 tyres was to do with width and not height? How would a 255 look taller over the 245 if its width related?
07-23-2015, 06:14 PM | #12 | |
Rep 63
Got it done now, thanks for the pics/advice - my post here: www.6post.com/forums/showthread.php?t=1154057 Cheers, |
04-21-2017, 10:29 AM | #13 | |
Rep 147
I have seen one of your old posts. What did you mean by " I went 245/285 because it was recommended". BMW recommends 245/275. On the other hand every caltulator on the web says 245/285 is the perfect match. Did You have any problems with xdrive and drivetrain on 245/285? I just bought 343M5 wheels and dont know whether I should go for 245/275 or 245/285 setup. Please help/ |
04-21-2017, 11:17 AM | #14 | |
Rep 553
Front: 245 * 35 = 85.75mm > convert to in = 3.38" Tot OD front = 3.38 * 2 + 20(size of wheel) = 26.76" Rear: 285 * 30 = 85.5mm = 3.37" Tot OD rear = 6.74 * 2 + 20 = 26.74" |
04-21-2017, 01:02 PM | #15 | |
Rep 1,715
