BMW M3 and M4 - The Icons
home
Classifieds Sponsors Classifieds Suspension / Brakes / Chassis / Spacers
      01-18-2024, 06:17 PM   #1
kevin @ eas
BimmerPost Supporting Vendor
kevin @ eas's Avatar
Drives: 2015 BMW M4
▀▄ eas | Paragon Performance - 2-piece Rotors - BMW G8X M2/M3/M4
Paragon Performance 2-piece Rotor offers superior braking and cooling efficiency optimized for track and race applications. It features 72 directional ventilation vanes to create suction, turbulence, and guides cool air through the rotor for improved heat dissipation and increased resistance to cracking under harsh track condition.
Made of CM-250 special formulated high carbon alloy cast iron, it allows for an optimal bite, thermal characteristics, high-temperature strength and durability. Rotor rings are heat treated to release stress in the rotor to avoid deformation and vibration then turned by state-of-the-art CBN surface machining to ensure better break-in with new brake pads.
Vibration is reduced as the rotor lateral run-out is kept within 0.03mm and well-balanced: variations are kept within 2 grams. All rotors went through rigorous quality control procedures and inspections to ensure the rotors are fit for their purposes. The floating 2-piece design allows thermal expansion of the rotor while minimizing deformation and ensuring the rotor is self-centered with the pads. A slotted rotor improves braking consistency by maintaining a clean contact surface and dissipate heat generated and gases released when the pads come into contact with the rotors. Slotted rotors have a superior advantage over blank rotors in wet or raining conditions by preventing water films to form between the brake pad and rotor surface. Weighing less than most O.E. rotors while maintaining proper thermal capacity, our 2-piece rotors improves overall handling by saving unsprung mass.
Aluminum hats are CNC machined from lightweight 6061-T6 aerospace grade aluminum for high strength and durability under extreme track conditions, then black hard coat/hard anodized to increase resistance to wear and corrosion. Mil-spec Type III anodized hats will not discolor under extreme heat, and are harder and more wear/scratch resistant. Unnecessary materials are taken out from the aluminum hats for maximum weight savings while maintaining proper structural integrity. Black anodized hard coat and standard hard coat hats are the same in terms of performance and durability.
Front Rotors
Rear Rotors
Features
- Direct bolt-on without any modifications and designed to work flawlessly with OEM ABS and brake system while maintaining factory brake bias.
- Compatible with OEM brake pads or aftermarket pads with the same pad depth (D)
- 72 directional ventilation vanes for optimal cooling performance, runs up to 30% cooler than O.E. rotors and increase cooling efficiency by up to 30%
- Floating 2-piece design
- Minimizing brake fade & judder during extended sessions
- Rotor to hat mounting system: D-Bobbin (Long) - 10-bolt
Vehicles Supported
BMW G87 M2
BMW G80 M3, including Competition
BMW G82 M4, including Competition
BMW G83 M4, including Competition
Ordering:
Phone:
You can reach us directly by calling 866.669.0705 to place your order over the phone.
Payment:
Credit/Debit Cards: Visa, Mastercard, Discover, PayPal, Google Checkout (available online & over phone)
Other Payments:
Money Order/Cashier’s Check & Bank Wire Transfer are also available. Please contact us to pay with either of these methods.
Shipping:
All orders will be shipping via UPS. If you are interested in shipping to Hawaii, Alaska, or internationally, please contact us directly, as you will be charged additional shipping fees.
Hours of Operations:
Monday - Friday from 9AM to 5PM PST
Saturday - 9AM-12PM PST
Sunday - Closed
Retail Location/ Installation Center:
Come check out our 8000 square foot facility in Anaheim, CA. We install everything we sell.
Contact Info:
Phone: 866.669.0705 x31
Email: kevin@europeanautosource.com
Website: http://www.europeanautosource.com
Feel free to contact me via PM, email, or phone if you have any questions.
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
g80
