11-24-2023, 12:00 PM | #1 |
Rep 204
B58 E85 Blending to increase output?
Came across a few articles on blending E85 & 91 octane as well as the below calculator. Given I’m in CA; it’s either 91 or 100 race fuel at $10+ a gallon.
Or, blending E85 & 91. Blended 4.5 Gallons of E85 & 16.5 gallons of 91; for a blended octane of 94.1 Octane or E27. In the future, I intend to blend 5.5 Gallons of E85 & 15.5 91 for a blended octane of 94.7 or E30. Cheaper way to improve power and mileage? So far, was able to run Map 7 on the Dinantronics X (suggests 93octane +) with no issues, knock, rough idle, etc. Thoughts? Fuel Mix Calculator |
11-25-2023, 04:20 AM | #5 |
Rep 66
I would highly recommend an ethanol content analyzer. I started by mathing my e-content, even got a tester but quickly found inconsistency at my local pumps.
After installing the fuel-it, I now get real time readings which takes some of the guess work out and gives reassurance I have the right mix. |
raannathr33327.50 |
11-25-2023, 08:25 AM | #6 | |
Rep 204
Yep, x5. Bummed they didn’t provide an x40i platform with the more powerful B58 found in the M340i & M440is. Would have opted for that engine platform. |
11-25-2023, 11:57 AM | #7 |
Joint Chiefs of Staff
24383
Rep 191,215
How are you checking this since Dinantronics does not datalog?
11-28-2023, 10:35 AM | #8 |
Rep 575
Drives: 2023 BMW M340i
Just a heads up, there’s not set ratio of 91 and e to make a certain blend. You have to test the e level of the e85 your pumping and input that into the calculator. Your suppose to test the 91 too, but I’m too lazy for that. I’d reccomend a flex fuel sensor if you ever get tuned.
raannathr33327.50 |
11-28-2023, 10:53 AM | #9 | |
24383
Rep 191,215
in my opinion a flex fuel kit is a must when blending E85 if the car is using a piggyback, get the Fuel-it kit if you are tuned with bootmod3, get the PTF flex fuel kit which allows bootmod3 to automatically adjust your map based off the E85 content.
11-28-2023, 04:06 PM | #10 |
Rep 566
gents the analyzers are great tools i love mine but don't get scared - figure out your ratio based on your local pump gas and e85 pump gas ratio of E and enjoy - a properly designed flash will give you alot of safe wiggle room in terms of e content typically as long as it doesn't exceed e50 - we were all doing just fine before these analyzers (although they are a great tool). And remember without additional fueling we really hit the limits of power gain somewhere between e30 and e50.
As an example mission and dinan offers a 100% e85 tune on an otherwise stock car and while it makes more power than stock it does not exceed the power delivered by an an e30 tune (again on an otherwise stock car) so its likely for the person that wants to enjoy the savings at the pump with a little power bump |
raannathr33327.50 |
11-28-2023, 08:56 PM | #11 | |
Professional Pisser-Offer
26
Rep 49
Edit: To clarify, I know stock fueling tops out around e50. Even cars with full fueling setups tend to run blends as opposed to full e85 Last edited by aleph-one; 11-28-2023 at 09:06 PM.. |
11-28-2023, 09:24 PM | #12 | |
Rep 204
I’ve heard a lot of the same feedback in other articles… E30 to E50 max seems to be a point where diminishing returns start to be realized. |
