BMW X3 Forum
BMW X3 Forum
Welcome to the ultimate BMW X3 community.
      06-23-2023, 03:24 PM   #1
StanislavH
StanislavH's Avatar
Ukraine
Drives: BMW X3 2012
X3 F25 encode the rear two-stage brake
Hi all. Connoisseurs, tell me how in bmw x3 f25 2012, you can encode the rear two-stage brake lights so that they work like dimensions and a regular brake light? This car is up to restyling and it has no drivers in the stops, there are incandescent bulbs.
And the second question, is it possible to somehow encode the stops so that there are no errors when replacing light bulbs with LEDs. Tried disabling hot and cold check and activated led, but the error is still there. Does anyone know how to fix this, please tell me!!!
If there are any F25 cheat sheets, please share!)
Sincerely, Stanislav
staniiiiislav@gmail.com
For example, I posted a photo that I can’t encode the dimensions and stop signal
      06-29-2023, 11:05 PM   #2
TheNine90
Drives: bmw
two-stage brake lights is different tail light hardware.
Which faults do you have, which lights did you change and which parameters did you set for LED
      07-03-2023, 11:20 AM   #3
StanislavH
StanislavH's Avatar
Ukraine
Drives: BMW X3 2012
Thanks for the answer @TheNine90.
I already figured out the two-stage stop signal, and realized that I needed to change the stops to Europe, it would probably not be possible for a friend to make the two-stage stop signal work like a normal stop + dimensions.
Yes, and by replacing the lamps, the led, too, by an experimental way, realized that it would not be possible to apparently put it in the stops.
The first thing I changed was:
FRM → AUSG_15_BL _L_KALT_UEBERW_AKTIV → nicht_aktiv
FRM → AUSG_15_BL _L_WARM_UEBERW_AKTIV → nicht_aktiv
FRM → AUSG_15_L_IS_LED → active
FRM → AUSG_16_BL _R _KALT_UEBERW_AKTIV → nicht_aktiv
FRM → AUSG_16_BL _R _WARM_UEBERW_AKTIV → nicht_aktiv
FRM → AUSG_16_R _IS_LED → active
This did not help, it gave an error about a brake light malfunction.
I started to understand further, I found how to get rid of the error:
FRM → DRL_MODUS → drl_s (was drl_h)
The error in the footsteps disappeared, but the dipped beam stopped working, as there are halogen lamps. I tried other options for DRL_MODUS, but alas, I realized that if I want LED lamps, I also need to change the headlights at least to xenon.
Here's a story, as a result, I changed only the rear turns and the rear turn on the led.
Maybe there are some thoughts?
Tags
coding, f25, stop signal
xbimmers
