      04-25-2022, 12:15 PM   #23
TinCanSailor
Fueled by Recycled Dinosaurs!
TinCanSailor's Avatar
813
Drives: F06 M6, F10 550i, E93 335i
Plus ya didn't have to put out a fire so that is good. Can you get the pcv by itself or do yu have to buy the entire cover?
      04-25-2022, 01:01 PM   #24
arucano
arucano's Avatar
2014 BMW M6 GC  [10.00]
It is not broken out as a separate part number. See illustration below.
F06 M6 Grand Coupe CP
Sapphire Black Metallic
The drive is the destination
      04-25-2022, 02:41 PM   #25
M6Roar
Drives: '14 M6GC
True Yeah the full cover must be replaced, injectors gasket ring & decoupling element and hpfp profile gasket with pipe
Found the part number but it doesn't exist.
Update: That is the part number for the kit 11158636541
      04-30-2022, 05:08 AM   #26
M6Roar
Drives: '14 M6GC
Found the leak yet not sure intake or valve cover
      04-30-2022, 08:40 AM   #27
M6Roar
Drives: '14 M6GC
Since the engine must be removed, what parts should I replace?
So far valve stems seals, Rod bearings, both intake manifolds
      04-30-2022, 09:32 PM   #28
TinCanSailor
813
Honestly, I'd be giving a call to Raza. These things are his passion and he will point ya in the right direction. Depending on your goals there are a number of items to be considered. He also makes a billet intake that would be a wise choice.
M6Roar103.00
      08-02-2022, 04:52 PM   #29
mperor617
Drives: BMW M5
M6roar - where was the leak coming from? Any updates?
      08-02-2022, 09:53 PM   #30
M6Roar
Drives: '14 M6GC
The intake manifold.
      07-12-2023, 03:15 AM   #31
UsedF10M5
They say I'm Invincible
UsedF10M5's Avatar
Drives: 08 E90 335xi 6AT
Given your code of Air Volume 2, was the intake manifold issue on bank 2?
      07-18-2023, 12:35 AM   #32
M6Roar
Drives: '14 M6GC
In my case yes. But in your case do a smoke test.
      02-29-2024, 03:22 AM   #33
Booda199
Drives: 650i F06 2013
hi,
i had the same issue before I rebuild the engine and I've changed everything ( vacuum lines, pcv,ccv system the hoses over the valve cover and the ones under the valve cover, 4 new Vanos solenoids, 8 brand new injectors, 2 air mass sensors, 2 intercooler sensors, 2 intake manifold sensors, and I checked the 2 intake manifolds for any leaks while the engine was out and there was no leaks at all, but i found out something weird, when I unplug the fuel tank ventilation valve located on bank 2 the engine works with no issue and the code doesn't get back until I plug it again. and I still don't know the issue..
please help..
i have a 650i GC 2013 with n63b4401 engine.
Copyright ©2000 - 2025, vBulletin Solutions Inc.
