      09-27-2020, 03:24 AM   #1
hugo_nz
New Zealand
156
Drives: F15 Xdrive50i
F12 Ambient Lighting Upgrade - Using OEM Optics
A couple of weeks ago there was a post about ambient lighting updates available to the F12/F13/F06. Long story short, without significant wiring and software updates there is no way to get multi-colour ambient lighting in our cars. This got me thinking about what options we had other than sticking aftermarket LED strips over the existing optics.
I found THESE on amazon. The thing that stuck out was that you could use the existing optics with the new light units.
This is the result:
Obviously the photos from my phone are enhanced so I did some manual adjustments to more closely simulate what it looks like in real life, and this is the result:
The result is not crazy bright or garish at all. I attached the supplied LED drivers to the factory optic strips. Running the connecting wires into the car was a wee bit of a challenge since there is no wire tunnel through the door harness. I overcame this by running them out the bottom of the door, under the rocker panel covers, illuminate sill plate and up into the car under the weather seal. Pretty clean, invisible install.
I added footwell lighting front and back using the supplied fibre optic cables. The optics are hidden under the trim panels and the rear seat bench so they are not directly visible.
Pretty happy with the result. Took a fair few hours to do but I did remove the seats to properly hide the fibre optic cables for the the footwell lighting. The cables are all routed to the armrest storage. The setup for the app used to change the colours was seamless and works as expected.
      09-28-2020, 06:16 PM   #2
Mennaf06
Mennaf06's Avatar
Drives: 2016 Bmw 640i
This is the result:
The result is not crazy bright or garish at all. I attached the supplied LED drivers to the factory optic strips. Running the connecting wires into the car was a wee bit of a challenge since there is no wire tunnel through eh door harness. I overcame this by running them out the bottom of the door, under the rocker panel covers, illuminate sill plate and up into the car under the weather seal. Pretty clean, invisible install.
Pretty happy with the result. Took a fair few hours to do but I did remove the seats to properly hide the fibre optic cables for the the footwell lighting. The cables are all routed to the armrest storage. The setup for the app was seamless and works as expected.
Wow well done. I love the look of it, I just don't think I can take on that project myself
      09-29-2020, 03:49 AM   #3
hugo_nz
New Zealand
156
Not going to lie, it's a doozy. The front seats came out to properly tuck the aftermarket optics under the trim panels, the cable routing from the doors is a major PITA, and you have to make some modifications to the original optics and door cards to fit the aftermarket light modules. BUT, none of it is too destructive and I could easily revert it back to stock if I wanted.
I was not convinced about ambient lighting until we got the X5. It left me wanting more every time I got into the 6. You could, conceivably use different controllers to power the upper and lower LEDs to give you a two-tone look as well.
      09-29-2020, 10:16 AM   #4
itzjoker
Results look great, I may have to do it on my 6! I know exactly how you feel...the ambient lighting is such a nice touch in our X6.
      09-30-2020, 07:07 AM   #5
RichNa
Drives: Bmw 650i (M6 converted)
This is the result:
Do you have the link ?
      09-30-2020, 08:40 PM   #6
hugo_nz
New Zealand
156
Yep, link is in the start* of my post.
      10-04-2020, 09:39 PM   #7
RichNa
Yep, link is in the star of my post.
Hey bro, I didn't quite understand what u mean by star, can you paste it to your reply 😅 thank you
      10-04-2020, 10:52 PM   #8
hugo_nz
New Zealand
156
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
      10-31-2020, 05:14 AM   #9
blackbmw2018
Drives: bmw 6
“I attached the supplied LED drivers to the factory optic strips.“
“make some modifications to the original optics and door cards to fit the aftermarket light modules”
What kind of modifications and how u manage connect to the original fiber?
      11-01-2020, 03:03 PM   #10
hugo_nz
New Zealand
156
Hey there. The original LEDs that light the strips clip into the door card. The fibre optics in turn have a little notch on them that clip into those LED emitters.
The modifications include cutting away the tab that holds the existing LED emitter to the door card, and then cutting off the notch from the existing optics to allow them to slot into the new LED emitters supplied with the kit. The factory optics are exactly the same diameter as the ones supplied with the kit so they fit perfectly once the little notch is cut off.
And yes, this can be reverted. The original wiring is left intact since it's not used in this retrofit. The factory LED emitters can be stuck down with some glue if you want to reinstall them. The factory optics can still slide into the factory LED emitter so no harm done there.
      11-01-2020, 06:59 PM   #11
blackbmw2018
Drives: bmw 6
Thanks for the explanation.
      04-18-2021, 02:37 AM   #12
hugo_nz
New Zealand
156
Update (18/04/21):
I decided to take a 2nd stab at the ambient lighting upgrade I did a while back. The first iteration was good, but the location of the fiber light guide meant that the light was inconsistent in both light output and also from a visual appeal perspective from the driver seat. Today I moved the driver side light guide up a notch from below the carpet strip where it was originally to below the leather strip. The results look much better!
I used an internet sourced image below to show the original (pink line) vs new placement (blue line) and then took some photos tonight to show the results on the driver side vs the current placement on the passenger side.
Current: F15 Xdrive50i. Mineral Silver Metallic. 20" Y-spoke 451
CIC to NBT Retrofit | NBT Glass Display Retrofit | Carplay MMI Retrofit | Ambient Light Upgrade | Massage Lumbar Retrofit | Gloss Glack LCI Kidneys
Past BMWs: F12 650i, E65 740i, E64 645ci, E39 540i, E89 118i
      04-19-2021, 12:49 PM   #13
Locasio
England
Drives: Bmw 640
This looks unbelievably good 👍
I HAVE to do this to my 2012 640. Been looking for something like this for a LONG time!
So the plastic clear strip that's in the door now that lights with a very dim orangey red comes away?
Replace whatever it is that's plugged into that with the drivers from the amazon thing and then plug the new light strip into that and run it in the space where the clear plastic strip was?
Sorry for the basic questions! I'm actually an electrical engineer believe it or not 🤣
      04-19-2021, 12:59 PM   #14
Locasio
England
Drives: Bmw 640
Sorry, also is this the correct package?
https://www.ebay.co.uk/itm/6M-RGB-LE....m46890.l49286
      04-20-2021, 08:09 PM   #15
hugo_nz
New Zealand
156
The optic strip (light guide) in the doors remain and are modified just a little to work with the RGB led lights (tiny little nub/catch needs to be cut off). This makes it easier to go back to the factory setup if required.
      04-20-2021, 08:11 PM   #16
hugo_nz
New Zealand
156
I would recommend these instead: Threadless RGB Lighting
This is a new threadless kit. This means that you wire the power directly in the doors, and the light modules connect wirelessly to the master control. This removes the need to thread wires from the doors into the cabin (which is not an easy task). I will be replacing my setup with these too soon.
      05-06-2021, 09:20 AM   #17
e38740imd
Drives: 2016 640i
these would be a great upgrade if we are able to switch the radio ac control panel lighting from orange to white.
      05-19-2021, 10:41 PM   #18
ex46fanatic
Wish we had red for sport mode. Blue economy...orange/white comfort?
      05-19-2021, 11:00 PM   #19
hugo_nz
New Zealand
156
It's not out of the realm of what's possible tactually. Without being too technical, when you change the drive modes the car sends CAN signals to several components so technically it should be possible to create an intercept module that can take that information and communicate directly with the LED control box to change the LED colours.
      05-22-2021, 07:44 PM   #20
ex46fanatic
I hope its only a matter of time before someone goes ahead with it and figures it out If you know more I'd love to hear it - any direction would help.
But just imagine how cool and fitting it would be too - how on earth did BMW not do this. Why did they do what they did ?!
      05-23-2021, 11:12 AM   #21
DaveS86
Drives: BMW 640I
I don't even know why they bothered fitting lighting in the first place. It is so dim you can't even see it unless you put your hand directly underneath the lights.
      05-24-2021, 02:19 PM   #22
Oris4
Drives: 2012 BMW X5 35i
Just finished this up over the weekend, a bit more difficult in an f06 but worth the work. Not sure if anyone is going to attempt this but I would be happy to guide, I did use the threadless kit and definitely much easier. I also used wire taps so no cutting/splicing.
Copyright ©2000 - 2021, vBulletin Solutions Inc.
