07-26-2020, 04:07 PM | #1 |
Rep 51
Enginge knocking
Hi guys,
So today I got the dreading drive train malfunciton. Car wouldn't shift properly. Pulled over and stop the car and restarted it. It cleared and was running normally. Then when I drove it under M1 setting , the engine was knocking and shortly after, got the high temp. warning light. Overheating i guess. Car is a 2017 M6 coupe with about 53500 miles. Bought it used. Just changed oil about 300 miles ago. Any body have any ideas or a reputable shop in the Walnut Creek, Ca area? I'm so bummed. Car was so fun. |
07-26-2020, 04:31 PM | #2 |
Rep 93
Check each spark plug for oil in cylinders... i got the drivetrain malfunction two weeks after buying my F10 M5.... needed new valve gaskets and cats as a result of the oil burn. Thankfully mine is under warranty, would have been $7k otherwise
07-31-2020, 02:50 PM | #4 | |
Fueled by Recycled Dinosaurs!
630
Rep 1,170
Drives: F06 M6
Very sorry to hear about the trouble. Sounds very similar to what just happened to me a few months ago, right down to the had just changed the oil recently with just a few hundred miles on the change. Below is a link from my experience. I can't say enough about the folks at RKAutowerks all the way through the process. They are absolutely the best and the most cost permissive solution out there. I'd be happy to chat with you about my car and what was done but I highly encourage you to call Mike or Raza. There is no hard selling and they will make every effort to educate you. Send me a DM with your number if ya want to chat. https://www.6post.com/forums/showthread.php?t=1729078
MMMM6GC275.00 |
08-01-2020, 09:40 PM | #5 |
630
Rep 1,170
Drives: F06 M6
Hey X-Tech7 adding this video here you shared with me, if ya want me to remove it I will gladly do so. This video is here to help others that might not know what a spun rod bearing might sound like. If you own an M5/M6 please seek the consult of an indy shop well qualified to work on M cars that can do a repair for your with good bearings before you end up needing a full engine rebuild. I can't take credit for the video but will say it sounds exactly like what I heard the night my engine ate itself while on a causal drive to take the love of my life our for her bday dinner with a group of good friends.
Sometime regular oil changes are not enough and in my case regular changes and rod bearing service by the dealer did nothing to stop the engine from dinning before my wife and I did.
08-02-2020, 12:37 AM | #6 |
Rep 51
Thanks TinCanSailor! I couldn't figure out to post it to share to the community. Hope this will give some insights to our cars and problems that may arise.
TinCanSailor629.50 |
08-02-2020, 12:27 PM | #7 |
Rep 360
So you had gone in and replaced your bearings as a preventative measure and you still encountered a failure?
08-02-2020, 04:29 PM | #9 |
Rep 582
I think I seen a post awhile ago not sure it was him but his original rod bearings failed and BMW replaced the bearings for him under warranty ,Im sure they used the same crap that comes in there ,so he failed a second time but that engine seemed to be doomed from the beginning ,they make better aftermarket bearings for this engine I think King bearing is one of them
LJohnson32212.50 TinCanSailor629.50 |
08-02-2020, 06:37 PM | #10 | |
Rep 125
08-04-2020, 08:11 AM | #11 |
630
Rep 1,170
Drives: F06 M6
Correct, my rod bearings had been done previously by the dealer under warranty and oil changes were done at an interval of approximately 7500 miles. I had just recently had an oil change performed before the bearings seized.
LJohnson32212.50 |
08-04-2020, 08:48 AM | #12 | |
Rep 125
Thoughts? |
08-04-2020, 10:11 AM | #13 | |
Rep 746
08-04-2020, 03:18 PM | #14 |
630
Rep 1,170
Drives: F06 M6
I will likely do more frequent changes. Crazy how our N63 powered 550 has done just fine with the service interval, well other than having to add oil due to consumption. Now that we are over 100k miles on the 550 and I have some Rennstands from Safe Jack I'll likely just start changing them both at 3k.
11-03-2020, 11:49 PM | #15 |
Rep 51
Well it's finally back from RK Autowerks! Had the car for about two weeks now. The guys over at RK really took care of me from start to finish especially Mike. He made all the arrangements from shipping the car to even filling the freon from the dealer. Even though RK was busy with other more monstrous project builds, Mike always kept me up to date with my rebuild with pictures and always answered any questions I had along the way. They were even working on my car on Sundays! That's commitment and dedication to their customers. I wanted to add the charge coolers last minute and even though he didn't have any on stock, Mike somehow made it happen in time. I could not be more happier with their workmanship. I did also add their Stage 1 tune . The car's power seems limitless. What I mean by that is that it once you press the pedal,the power comes instantaneously. There is no hesitation even at efficient and comfort settings. The car just wants to be pushed. Now I really can't compare to other cars out there, but it's pretty fast too me . Definitely feels way more responsive. As unfortunately as it is about my engine failure, I am also fortunate to have it rebuilt by RK Autowerks. They have done a phenomenal job. Also a big thanks to Tincan Sailor for his advice and wisdom. I hope your M6's never has a total engine failure, but if you do need a rebuild, please look no further than RK Autowerks. Mike will take care of your car the right way. It truly was a stress free experience. If you do have your car shipped to them, be aware there may be different prices to and back. This is no fault of RK Autowerks, but I assumed it be the same round trip. Sorry for the long winded post, but I can't help express my gratitude for Mike and the crew at RK Autowerks.
11-04-2020, 07:21 AM | #16 | |
630
Rep 1,170
Drives: F06 M6
11-04-2020, 03:20 PM | #17 |
Rep 582
I watched this vid from Evolve a BMW performance shop in the UK,they flew down Raza to build the forged 1000hp engines from Rk Autowerks
01-17-2021, 08:56 PM | #19 |
630
Rep 1,170
Drives: F06 M6
Hey x-tech; I hope all is well brother. checking in on the engine break-in. Got your package and can't thank ya enough. I have been wanting to get a set esp having carbon ceramic brakes. I can't wait to get home and put them to work.
