03-29-2017, 03:37 AM | #1 |
Rep 2,560
Drives: Rapidly from A to B
Camber affect on toe in?
Question for anyone who has added camber plates. Does taking the camber more negative increase the toe out or does it increase the toe in?
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
03-29-2017, 01:23 PM | #2 |
Rep 1,084
tie-rod attach point is slightly higher than the pivot when changing camber with plates, so adding negative camber gives toe-out
rwalker@rwalker.com (I really dislike Private Messaging)
03-29-2017, 07:37 PM | #3 |
Rep 2,560
thanks
03-30-2017, 06:14 PM | #5 |
BimmerPost Supporting Vendor
3881
Rep 54,449
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
03-31-2017, 09:44 AM | #6 |
Rep 3,714
I saw you have camber plates on your M2. Did you set your street alignment to 0 toe and when you put negative camber in at the track it goes to toe out a bit for better turn in?
Or did you just do something like -2.5 and 0 toe and leave it? |
03-31-2017, 12:56 PM | #7 |
Rep 120
-2.5F camber, 0 toe, and leave it.
CosmosMpower2050.50 |
